Does anyone know what type of fixing this is and how I can remove it?
Sent from my SM-G930F using Tapatalk
What fixing
- Has thanked: 200 times
- Been thanked: 482 times
Re: What fixing
Looks like a rawlbolt sleeve . Removing it could prove very messy and create a larger hole than you have now. Probably the best option would be to knock it further into the wall and fill over.
- mole81
- Has thanked: 39 times
- Been thanked: 4 times
Re: What fixing
Thanks I'll try that then, what's the best way to knock it in further?Grendel wrote:Looks like a rawlbolt sleeve . Removing it could prove very messy and create a larger hole than you have now. Probably the best option would be to knock it further into the wall and fill over.
- Mr. Grumpy
- Has thanked: 25 times
- Been thanked: 109 times
Re: What fixing
anything that comes to hand, masonry drill bit, bit of wood, old screwdriver +hammermole81 wrote:Thanks I'll try that then, what's the best way to knock it in further?Grendel wrote:Looks like a rawlbolt sleeve . Removing it could prove very messy and create a larger hole than you have now. Probably the best option would be to knock it further into the wall and fill over.
You only need 5mm or so to polyfill over.
- These users thanked the author DIY_Johnny for the post:
- mole81
- Job and Knock
- Old School Chippie
- Has thanked: 742 times
- Been thanked: 1572 times
Re: What fixing
Hammer and piece of threaded rod, rebar, drive rod (T-handle) from a socket set, very large old screwdriver, etc. It just needs something of steel with a large enough diameter to sit on the end of the Rawlbolt. Or as Johnny says - anything that comes to hand
- These users thanked the author Job and Knock for the post:
- mole81
