Damp Proof Tanking Height
- Has thanked: 1 time
Can anyone advise what level tanking should go up to where the area to be tanked is lower than an adjoining retaining internal wall, the lower ground level is about 50cm below the upper floor level?
- Has thanked: 6 times
- Been thanked: 187 times
Re: Damp Proof Tanking Height
can you post photos of the problem, inside the house and outside. i dont understand what youve writen.
Hi, the attachment probably illustrates better than a photo would. I'm trying to find out how far up the tanking should go within the lower floor area - just to the 50cm or this plus a minimum height above
- Coachhouse ground levels.ppt
- (118 KiB) Downloaded 178 times
