Last weekend I installed a new shower valve, I went away for a night and a slight leak has soaked into the wall, which I have been trying to dry out in the few days since.
I was hoping to finish the installation of the shower this weekend, which would involve installing plasterboard over the studs on the wall, then a shower wall board ontop of that.
I was wondering whether I can do that with the wall still being a bit damp or whether this is a terrible idea?
Plasterboard over slightly wet wall
- wine~o
- Has thanked: 1413 times
- Been thanked: 3991 times
Re: Plasterboard over slightly wet wall
Probably best to let it fully dry. Are you certain there are no remaining leaks/weeps ?
- steviejoiner74
- Has thanked: 747 times
- Been thanked: 1616 times
- Has thanked: 6 times
- Been thanked: 187 times
what have you been trying to dry out? a masonry wall,studs?what about the floor and any ceiling below?
is there another wall behind the valve position?
if ypou leave wet work overnight then isolate the supplies.
- Mr. Grumpy
- Has thanked: 25 times
- Been thanked: 109 times
You would be surprised what a heater and a fan can do to a wet wall.
Even defrosting the freezer, a fan blasted at an iced up freezer will defrost in no time at all
- Has thanked: 2 times
Just trying to dry the wall (concrete block), the studs and floorboards have already dried.wes56 wrote:what have you been trying to dry out? a masonry wall,studs?what about the floor and any ceiling below?
if you leave wet work overnight then isolate the supplies.
Luckily the bathroom overhangs an alley (between houses on a Victorian terrace), so the water from the leak just ended up outside, the "ceiling" of the alleyway is just a sheet material (can't remember which one off the top of my head) so I will investigate later and replace if need be.
