I have 4 mains halogen downlights in a bedroom and I want to put in a single LCD wall light. Can I simply take a spur off of the lighting circuit.
See attached picture of connections - I asuume that I will need change the terminal blocks for a small junction box or put in a chocbox enclosure.
The wall light has its own switch and I want to operate it independently from the ceiling lights so I know I have to connect to the main lighting ring.
Thanks for reading this and in anticipation of a response
Ian
Spur off of a lighting circuit
- wine~o
- Has thanked: 1413 times
- Been thanked: 3991 times
Re: Spur off of a lighting circuit
First. lighting isn't on a ring, it's on a radial circuit.
Second. can you take a feed (spur) from it. Yes you can.
Third. any junction box must either be accessible for maintenance or be maintenance free (Wago connectors for one example) .
you say "The wall light has its own switch"
what exactly do you mean ? is there an existing wall light ? if so does it switch on/off with the downlights ?
- Has thanked: 1 time
Thank you. Understand its radial not ring. Great that I can spur off of it. Was going to take spur to a fused switch, but the light is a picture light with an integral pull cord switch. Junction (box) will be accessible (in the ceiling) in the same way as the terminal block is now.
Hope thats all okay.
- wine~o
There's accessible and accessible.
- wine~o
Make sure all wiring is within "permitted zones" and complies with BS 7671...
