Hanging light to spotlight
- Has thanked: 7 times
- Been thanked: 1 time
Looking to change this :
https://ibb.co/gmi3kx
to this :
https://ibb.co/cVWaXc
with this :
https://ibb.co/ijYB5x
Dad was a spark by trade when I was growing up, and a general all round handyman, so I've picked up a few things helping him out..........but he's now no longer here.
My question is, how do I go from the 3 wires from the hanging lamp (earth, black and red), down to 2 for the spotlight?
I've got the power drill and the cutter in order to cut the hole needed in the ceiling, have a drum of 3 core cable sitting around, and I'm thinking I'll be possibly needing a connector block too?
This is the area above the ceiling in the loft :
https://ibb.co/dG1Zsc
The area in question is further ahead than the existing spot thats at the bottom of the pic.
I'm 6'7" so looking to avoid becoming a contortionist to go up there if I possibly can.
Of course, many thanks in advance.
David
to this :
with this :
David
- Someone-Else
- Has thanked: 42 times
- Been thanked: 2487 times
Re: Hanging light to spotlight
Why?
Why do you want to change from a pendant lamp to a single downlight?
A pendant lamp will illuminate the whole room, a downlight will barely light the room but will point at what is directly under it.
But back to your question, if you must. Red and Black make no difference which way round they go. the 3rd wire is earth, which you new fitting does not require. So put green/yellow sleeving on the earth, and a single choc bloc on the end of it (Or a wago connector, if you have) DO NOT cut the earth off.
- Someone-Else
No!
It may sound a good idea, but trust me it isn't.
After a while (depending on various factors) the tape will either come "dry" and fall off, or the "sticky" will run and the tape will fall off. Trust me, i have seen both happen.
Ebay less than £1.50 for what you want.
Other suppliers are available
- Someone-Else
NO, you neglected the earth. And as I said one down light is not a good idea.
I appreciate the concerns about the effects of the downlighter, but its only a box room.....one light is all thats needed.
Black and red wires connected.....and the earth sleeved, is that all?
- Someone-Else
.........and choc bloc / wago connector on the earth, After the sleeving.
- Has thanked: 3 times
- Been thanked: 18 times
Sleeved and into choc block.Borvad wrote:I appreciate the concerns about the effects of the downlighter, but its only a box room.....one light is all thats needed.
As said unless you enjoy the dismal prison cell look even a box room needs more than one downlighter. Still, it's easy and cheap to add a few extras when you find it too dark.
- Someone-Else
columbiers wrote:unless you enjoy the dismal prison cell look
