wood floor.. poured concrete over wood sub floor?!
Can anyone identify this & how to remove it?
I managed to crack a few tiny 2cm few pieces off with an SDS chisel but it took a good hour. It's about 17mm thick
Although it looks like concrete SDS chisels don't seem to crack it apart.. they mostly just sink in.. and then go through the wood subfloor!
It's also full of nails inside the material itself hidden beneath the surface.
It almost looks like concrete poured over nails but maybe I'm wrong!?
- IMG_3066b.jpg (541.72 KiB) Viewed 2701 times
- Has thanked: 855 times
- Been thanked: 994 times
Re: wood floor.. poured concrete over wood sub floor?!
I will make no guess as to what you got. But there are a couple of bits that may help:
a. an SDS bolster which should have a bit of a curve to it (cranked?) e.g. https://www.amazon.co.uk/Toolzone-Plus- ... B000V9IXE0.
And whilst I was trying to figure out what is the thing above called I came across this:
b. http://www.toolpak.co.uk/sds-max-floor- ... hisel.html
Just a couple of ideas until the cavalry comes along.
thanks.. I tried that SDS tile chisel but no luck.. it's rock solid like concrete !
- davyp1
- Has thanked: 13 times
- Been thanked: 181 times
I too would not like to guess at what you have got!
But if it was mine, I would want to know the just what this floor was made up of so I could consider just what to do with it!
I personally would mark out a "Test hole" approximately 30cm square and remove it, cutting down through the 'Sub floor' you mentioned.
Only by knowing what you are up against, can you decide just how to proceed!
Davyp1
Davyp1
I have already removed 30cm square of it, and still don't know what it is.davyp1 wrote:I personally would mark out a "Test hole" approximately 30cm square and remove it, cutting down through the 'Sub floor' you mentioned.
Davyp1
How does cutting through the subfloor & messing that up help me to know what it is? You've lost me there
I have a few more things to try.. after that.. I'm not one to give up usually but I'm on the verge of just laying laminate on top!
Hard to understand from the photos. Does it have lines to make it look like tiles? It could be cement (snowcrete) + a dye to make it the colour of clay tiles. It does not really matter, as long as you can get something that can get underneath it and separate it from the floor.
If you use the bolster running it parallel to the wooden floor, does it not get under the stuff to separate it from the wood (as opposed to going from the top down to the wood)? Just askin...
- Mr. Grumpy
- Has thanked: 25 times
- Been thanked: 109 times
Probably the SDS drill is too small. I have an older version of thisTitan and it will take that out in no time.
- BANNED
- Has thanked: 216 times
- Been thanked: 1070 times
Bit of a job to tell by the photos but, it could be asphalt tiles glued down to the boards, if it is then they can contain asbestos.
- Mr. Grumpy
why are you taking it up anyway? if it is that solid can you lay your new floor on top of that?
- wine~o
- Has thanked: 1413 times
- Been thanked: 3991 times
Looks like a terracotta tile laid on a tile adhesive from here. a tile removing sds + bit such as this https://www.screwfix.com/p/dewalt-sds-p ... 50mm/8660v
Should make light ish work of it. Other makes are available.
- Cantseeitfrommyhouse
- Has thanked: 36 times
- Been thanked: 108 times
my weapon of choice for med duty tile removal >> https://www.toolstation.com/shop/Power+ ... ter/p23991
Has done several hundred sqm of tiles now and still looks new.
^ ThisDIY_Johnny wrote:Probably the SDS drill is too small. I have an older version of thisTitan and it will take that out in no time.
and
^ This?DIY_Johnny wrote:why are you taking it up anyway? if it is that solid can you lay your new floor on top of that?
