Kitchen sink plumbing
- Has thanked: 6 times
Hi first time poster.
I recently had kitchen worktops fitted and new sink and mixer tap with pull out spout installed. There is a problem with hot water supply to the tap with very low flow (was fine with previous tap). Really too low to be of any real use. I checked and the tap connector has been installed with a kink in it (the tap came with what I think are proprietary push in connections on the end of the supplied tap connectors which look vaguely like the audio connectors in the image below!)
Photos of the installed pipework - best photos I could get. The HW supply was originally the copper pipe at the rear pointing to the left. All the other bits of plastic/copper pipe were added by plumber.
To my untrained eye the plumbing seems completely illogical. Plumber denied there was a problem and said it was a safety feature of the tap (which probably is a thing but there is only a dribble of water coming from the tap).
Am I correct I saying it has not been a job well done? Any reason why I should just have a go at removing some of the excess pipework and trying to get things straightened out myself?? Will the tap connector now be kinked forever?
Thanks in advance.
Thanks in advance.
- Someone-Else
- Has thanked: 42 times
- Been thanked: 2491 times
Re: Kitchen sink plumbing
Get your plumber back, and let him fix it. Those are flexible connections and they are kinked.
- chrrris
- Has thanked: 234 times
- Been thanked: 410 times
Your plumber is a cowboy. The flexis should have no kinks at all (because kinks cause the flow problems that you're having). And, while everyone has bad days occasionally, the really unforgivable thing is he didn't hold his hands up and apologise for his mistake when you pointed it out to him, instead spinning that yarn about it being a safety feature of that tap, which is complete and utter BS.MalloryWeiss wrote: To my untrained eye the plumbing seems completely illogical. Plumber denied there was a problem and said it was a safety feature of the tap (which probably is a thing but there is only a dribble of water coming from the tap).
Yes, you could fix it yourself. The existing flexis themselves may be alright if you unkink them, although they may be irreparably damaged. They're basically rubber hoses with a braided metal protective outer layer. After being severly kinked, they either may not "unkink" properly, or they may leak if disturbed. You should be able to buy replacements if you need them - they usually have either 10 or 12mm threaded connectors that go into the base of the tap and seal with rubber O rings. https://www.screwfix.com/search?search= ... +tap+tailsAm I correct I saying it has not been a job well done? Any reason why I should just have a go at removing some of the excess pipework and trying to get things straightened out myself?? Will the tap connector now be kinked forever?
- These users thanked the author chrrris for the post:
- MalloryWeiss
- Been thanked: 187 times
no plumber installed that mess. you might have problems if you have to get up to reconect atthe tap tails. shortening all that bits an peces of pipework will take the kinks outof the flexis.
youve not asked but the installer seems to haave cut out the back of the unit to bring in the supplies. an do you have a prper trap?
maybeyou should pull the lot back to where the supplies come into the cabinet and then redo it all.take care the pull out hose isnt fouling the flexis
- These users thanked the author wes56 for the post:
- MalloryWeiss
- Has thanked: 248 times
- Been thanked: 208 times
I didn't notice the trap till you mentioned it. What a dog's dinner. Bodged everywhere.
Thanks for the replies.
I shortened the pipework and straightened the flexi hose and water flow is acceptable!
The black hose is draining the 0.5 of a 1.5 bowl sink. It then connects into a proper trap. This is the same configuration as it was previously. I assume that is ok?
Needless to say that 'plumber' won't be back.
Thanks all
If he didn't take the care (or have the skill/knowledge) to do it right in the first place, I really wouldn't trust him to put it right.someone-else wrote:Get your plumber back, and let him fix it. Those are flexible connections and they are kinked.
Thanks all
- Has thanked: 4 times
- Been thanked: 27 times
It looks as though it drops quite a way before coming back up into the trap. Having the bottom half full of water isn't ideal.MalloryWeiss wrote:The black hose is draining the 0.5 of a 1.5 bowl sink. It then connects into a proper trap. This is the same configuration as it was previously. I assume that is ok?
Can you get a picture from slightly further back so we can see the pipes better.
- These users thanked the author mike10 for the post:
- MalloryWeiss
mike10 wrote: It looks as though it drops quite a way before coming back up into the trap. Having the bottom half full of water isn't ideal.
Sorry for the delay - been away over New year. I have attached photo. It does dip down and then come up to the trap. Should I shorten the black hose in this case?
This 'plumber' lost himself some work as my hot water storage tank has sprung a leak (the joys of buying and old house!) and he definitely didn't get the call for the work!
I would reduce the black hose length definitely. You'll get water sat in the dip which will smell and eventually build up with scum and grime.
- These users thanked the author Ktuludays for the post (total 2):
- mike10 • MalloryWeiss
- Rating: 14.29%
Yes, as Ktuludays says, it would be best to shorten the black pipe so that less water sits in it.
- MalloryWeiss
- wine~o
- Has thanked: 1414 times
- Been thanked: 3992 times
That black plastic flexi is a bodge. (waste) Your so called plumber isn't even a decent handyman...
you need summat like this
https://www.screwfix.com/p/mcalpine-dou ... 40mm/71787
1/2 an hour job for a competent plumber/handyman.
- chrrris
Wine~o's right. It should really have a proper 1.5 bowl waste and trap. The black flexi is an overflow waste connection and isn't really designed to carry the volume or type of waste from a kitchen sink (bits of food, grease, fat, etc). Unless you're very careful about what you put down it, it'll block eventually if left.
PS. Well done to the original poster for sorting out the tap connectors, and well done also on making the correct decision not to get the so-called plumber back in. I wouldn't even want him in the same county as the pipework in my house!
