I've attached 2 photos of my kitchen wall. On the other side of the wall is the outside. I've recently noticed 2 patches high up on the wall. In these patches the paint appears to have a layer of what can be best described as 'fizzy looking paint' (see close-up photo). This fizz can be wiped off with the paint underneath looking ok. There are no damp patches in the ceiling or below this.
I appreciate you can't comment on where water is coming from - I'll investigate. But just wanted people to chime in and confirm this appearance would be due to water damage.
Thanks.
https://imgur.com/TMWD4bG
https://imgur.com/tVQ9xE0
Does this look like damp?
- Been thanked: 1 time
Re: Does this look like damp?
It's flaky as seen in the close up photo. You can possibly see where I've swiped a bit of it away with a finger. The paint underneath remains intact though.
- Someone-Else
- Has thanked: 42 times
- Been thanked: 2491 times
a Damp meter is nothing but a glorified multi meter, I wouldn't waste money on one.
To check for damp why not put a piece of paper on it and see does said paper darken, if it does, its damp, but it does look like some sort of crystal.
- multiman
- Has thanked: 6 times
- Been thanked: 187 times
if the wall is dot an dabbed it culd be damp coming thru the adhesive dabs. a photo or two from outsidecould show more. is there an extractor in the kitchen?
was there aaa old chimney breastthere?
