Patio installed to high I've removed it, now what?
- Been thanked: 2 times
So as I guess with most people, you buy a house and all is well for a while, then You start to notice the issues!
So one of many is that the patio appeared to be above the dpc and as we have been having issues with damp I started to investigate as you do!
So fast forwarding a few months and digging, the patio slabs where sat on another patio and under those slabs was a concrete base! So over the years it's just been covered rather than removed.
So i set about removing some of the slabs and then digging down against the wall to basically make a trench that's below the dpc.
Now that's pretty much where I'm at, I've considered maybe some kind of French drain or just gravel I'm just not sure what's best, should I rip the whole patio up? just leave what's there?
Just need some pointers and ideas guys
Thankyou!
Thankyou!
Re: Patio installed to high I've removed it, now what?
So I posted quite a while back about how the drain looked which was pretty grim it also gives an idea of how high the patio was at the time :
So moving forward it looks like this, with the tide mark quite visible under the patio doors:
I'm planning on painting the walls as a lot was flaking so been brushing off all the loose stuff beforehand.also I've repointed a few parts since the pics
Cheers guys
Cheers guys
- Has thanked: 283 times
- Been thanked: 397 times
I would take up what is there and run a aco plastic drain close to the house and into the drain on the left hand side.
Mike
Mike
- multiman
Yes, otherwise you are inheriting someone else's bodge .
Mike
Mike
- multiman
- Has thanked: 6 times
- Been thanked: 187 times
i tried to help you with this busines in march 2016but you blanked me post and shot off until now.
theres a much better soluton but i'll leave you to sort it out.
@wes56 just looked back at my old post and it's the first time I had seen that reply,certainly didn't blank you?The issues where different to what we have now and other things took priority at the time.(mainly life )
Any input you have would be helpful.
- Has thanked: 100 times
- Been thanked: 1022 times
Assuming you plan to live here a long time, did it up and start fresh. An Aco drain as mentioned can be installed, they are a little unsightly but effective and easy to clean etc. A gravel top french drain looks nicer and is cheap to do, but harder to clean if you have a problem and prone to growing weeds etc.
