Replacing loop-in light fitting with chocolate box fitting
matt_b
Post by matt_b »
Hi all,
I have bought a new light fitting to go in my lounge. The existing light is a "regular" 60W bulb hanging from a rose. There are two switches to control the light, one by each door.
My existing rose looks like this:
Existing rose
Existing rose
My new light fitting has a single choc box:
New light fitting
New light fitting
The connections I am about to make are:
  • The left black wire to N
  • The other black on the right to L
  • Both green to earth
  • Add in an extra single choc box to connect both reds together
Is this the right thing to do here?
Thanks for any replies
Matt
Has thanked: 42 times
Been thanked: 2491 times
Re: Replacing loop-in light fitting with chocolate box fitti
Yes, but also put some red or brown tape on the black that is on the right. It will help in the future.
multiman
Return to “Lighting”
