Silvercrest Karaoke SKS 15/A1
- Has thanked: 31 times
- Been thanked: 14 times
Hi folks, tearing my hair out with trying to set this up, bought it a few years ago and have had a few tries with no success!
I have a LCD TV (sony) doesn't have the red yellow white inputs but the set did come with scart plugs for input and out put, I have a Blu-ray DVD player which does have the coloured inputs, I also have an Onkyo 3.1 that has a white and red input, I have no idea how to get this thing up and running, have looked on the Utube for vids but they only unbox them and so far haven't found any other source to guide me through it. We are having friends round on Friday and the wife is obsessed with getting this going! already had a domestic!
I also have a Humax freetime freesat sat box but don't know if I could do something through that, any advice to help me out would be much appreciated.
- Has thanked: 1299 times
- Been thanked: 1175 times
Re: Silvercrest Karaoke SKS 15/A1
Don't know exactly what you're doing, but you can get adaptors from RCA component (the yellow/red/white sockets) to / from scart. Either as a sort of "scart plug" with the yellow/red /white sockets on it, or a scart plug with leads and RCA plugs.
Dave54 wrote:Don't know exactly what you're doing, but you can get adaptors from RCA component (the yellow/red/white sockets) to / from scart. Either as a sort of "scart plug" with the yellow/red /white sockets on it, or a scart plug with leads and RCA plugs.
yes I have all these but it doesn't seem to work with every permutation I try
Thanks anyway
- Someone-Else
- Has thanked: 42 times
- Been thanked: 2487 times
Have you tried plugging the the leads into the scart adaptor, then selecting on the TV which "input" it should use.
As I understand it, a TV normally changes over to any scart device IF there is a voltage on a specific pin, which you wont have.
Steveuk23 wrote:Are you sure the yellow/red/white connections on the DVD player are inputs and not outputs
Sent from my SHIELD Tablet K1 using Tapatalk
Don't have clue!
- Timllfixit
- Has thanked: 146 times
- Been thanked: 209 times
Yellow is video. Red is audio(right), White audio (left). Lots of tellys have these "coloured"(RCA/phono) sockets, often on the side somewhere. There might be there, just hiding under a little flap. If you have them then you probably need the "AV" input. There are plenty of videos on U-tube, some of them are even in English.
- joinerjohn
- Has thanked: 17 times
- Been thanked: 315 times
Ahh well, at least ya know how to "unbox" it now.caravan72 wrote:Thanks for all the replies, I have looked on u-tube but have have only sourced un-boxing videos!
Cheers
- Has thanked: 775 times
- Been thanked: 3311 times
My advice for all Karaoke machines is take a sledgehammer and smash it to bits
Hope that helps
Hope that helps
- Someone-Else
Probably gave up, he asked the question 4 months ago.Pat68 wrote:Have you tried one of these leads?
A/v to scart leads (see pic)
http://imgur.com/pIimMfW
- joinerjohn
Nah,, didn't you see him on BGT last night?someone-else wrote: Probably gave up, he asked the question 4 months ago.
Just stumbled on this and 'Yes' I still don't have clue how to get it to work! just the wife asks me if I can set this up for a night! No! I effing can't! sorry and yes, I should take my 3 pound mash to it!
Just tell me there is a cheap and easily to operate karaoki set up out there I can use?
Cheers
Cheers
