telephone fault
telephone fault
My incoming telephone line from exchange is fine. However, when I replace cover and plug in my phone - nothing . no dial tone, no internet. I have changed the master socket and extension socket. Blue / white wire to 5, white / blue to 2 and orange to 3.
Where could problem be ?
- ayjay
- Has thanked: 458 times
- Been thanked: 1708 times
Re: telephone fault
Have you tried a different phone?Melvyn 84 wrote:My incoming telephone line from exchange is fine. However, when I replace cover and plug in my phone - nothing . no dial tone, no internet. I have changed the master socket and extension socket. Blue / white wire to 5, white / blue to 2 and orange to 3.
Maybe borrow a neighbours if you don't have another.
- Has thanked: 94 times
- Been thanked: 858 times
Re: telephone fault
faulty faceplate or a wiring fault, what master socket did you fit ? is it a proper filtered bt one (nte5, etc) adsl or infinity (fibre) ??
- moderator2
- UHM Super Moderator
- Has thanked: 154 times
- Been thanked: 560 times
Re: telephone fault
Melvyn. You have inadvertently posted in the wrong section. I'll move it to Communications and broadband (Subsection of Computers) in a mo.
- Someone-Else
- Has thanked: 42 times
- Been thanked: 2488 times
Re: telephone fault
Have you metered the phone cables that connect to the master socket?
- joinerjohn
- Has thanked: 17 times
- Been thanked: 315 times
Re: telephone fault
Had this with my home phone just last week. Took the faceplate off and plugged directly into the master socket behind it and the phone worked, but with the faceplate on there was nothing. It was the whole faceplate (not just the bottom section) that was faulty. A new one from Maplins sorted it out.
