Evolution Fury B&Q
- Has thanked: 25 times
- Been thanked: 14 times
Re: Evolution Fury B&Q
Not sure why your effort with the hand mitre saw is rubbish as it is not exactly the largest, thickest skirting you are cutting so, if you have no planned further use for a compound or sliding mitre saw then I would suggest you double check your angles as it may not be a 45 degree angle that is required and then do a bit more practice with your mitre saw.
Cheers, john
Cheers, john
- Has thanked: 75 times
- Been thanked: 4 times
John, I know, I'm a sad case. At the moment I am practising on some 9cm pine.jmcp wrote: Not sure why your effort with the hand mitre saw is rubbish as it is not exactly the largest, thickest skirting you are cutting so, if you have no planned further use for a compound or sliding mitre saw then I would suggest you double check your angles as it may not be a 45 degree angle that is required and then do a bit more practice with your mitre saw.
I bought a new blade for my old non-electric mitre saw.
And,
I bought a digital mitre finder.
The external angle of the wall is obtuse 44 degrees. The hand mitre mitre saw only goes to 45 degrees and only locks on 45 degrees and every 5 degrees from there up.
Also, because I have to saw the skirting vertically, by the time I have sawed to the bottom, the cut line is a bit wavy.
Yesterday, I messed about all day, and then after the air was blue, I dashed off to B&Q for the Evolution Fury impulse buy. It's still in the box in the hall. So, that's where I am now.
- Job and Knock
- Old School Chippie
- Has thanked: 742 times
- Been thanked: 1572 times
Of course the other thing which often doesn't help is having skirting which are cupped across their width. Are yours really flat?
Shouldn't be cupped. I ordered the machine cut beech wood a while ago and it is lying flat in the garage. Also only 8cm high so probably ok.Job and Knock wrote:Of course the other thing which often doesn't help is having skirting which are cupped across their width. Are yours really flat?
p.s. One of my posts said the external angle was obtuse, I think I meant acute. But I have learned since that if the external angle is out a degree or two, just mitre at 45 degrees anyway.
- big-all
- Pro Carpenter
- Has thanked: 731 times
- Been thanked: 2305 times
thats no guarantee off anything if its going to cup it will cupzaffy wrote:Shouldn't be cupped. I ordered the machine cut beech wood a while ago and it is lying flat in the garage. Also only 8cm high so probably ok.Job and Knock wrote:Of course the other thing which often doesn't help is having skirting which are cupped across their width. Are yours really flat?
- Timllfixit
- Has thanked: 146 times
- Been thanked: 209 times
Hi Zaffy,
I'm not sure where you are, but if you are a COSTCO member the Avonmouth store have(or had until recently) a very nice Metabo sliding mitre saw for £150(+ vat). I would have bought one but my wife had bought me an Einhell for Cristmas last year. I'm getting fed up with it though because I have to set it up every time I change the angle of the cut.
Thanks, Tillit, for thinking of me, but I'm a little over 100 miles away and not a member of COSTCO. Hopefully, the tip might help someone else out.Timllfixit wrote:Hi Zaffy,
- Has thanked: 61 times
- Been thanked: 184 times
I did the skirting in two entire houses, plus half of my mums house with a cheap mitre saw from B&Q, some unknown brand. It was the first "electric Saw" of any type I owned. Just need to take your time.
First mistake I made was assuming the saw was square out the box, read the manual and check the blade and table are square, then check the 45o angle is true. I only recently upgraded to a larger sliding compound mitre saw.
This looks ok to me: https://www.diy.com/departments/evoluti ... 514_BQ.prd
AH
AH
- UHM Super Moderator
- Has thanked: 27 times
- Been thanked: 63 times
If you want to discuss a particular tool, then it's better to start a new topic, than to dig up a thread from four and a half years ago.
Thanks. I've locked this thread.
