Hi there, went to Howdens yesterday as I couldn't work out how to fit my 3 drawer pack together, in fact I spent \ couple of hours the night before trying to figure it out only to grt up in the morning and took a quick look at the instructions that came witht he door front to realise how to do it but went to howdens anyway. Well standing in my local depot looking at the people serving there I thought, 'whats the chance they will know' when I spotted a senior looking guy putting a kitchen display together! I showed him the instructions and he responded by saying 'oh, the special instructions! he explianed how he puts them together and other tricks and after puting them together and looking at them he was right right but a little more understanding and they would have been a little higher but I'm happy with what I have and the wife has filled them already!
Now the for the units you pull out! what challange could they be like!
Howdens drawers
- steviejoiner74
- Has thanked: 747 times
- Been thanked: 1616 times
Re: Howdens drawers
Did you get the large instructions book with your supplied kitchen? It has all you will need in there caravan72.
- Has thanked: 31 times
- Been thanked: 14 times
Re: Howdens drawers
Yes I have the large instruction booklet, thats the one the senior fitter remarked 'special instructions' it has measurments showing how to hang the drawer runners and assemble the drawers, the fitter advised me to fit the rails and asseble the box without fronts and inset the drawer front connection into the drawer sides and fit the box in place then measure from the bracket down to the base of the unit then pop out the connections and fit to the front, I set the vetical adjustment to mid way but should have set it to it's lowest point then measured it to give me a more up adjustment (just a little more knowledge) but it's ok, the pullouts I've seen were usually mounted in the centre of the unit but howdens are side mounted so back to the 'special instructions'
Re: Howdens drawers
Re the Howdens drawer unit there are small dot indents inside the unit where the screws for the runners go. 2 dots for each runner. You can then add as many screws as you need. Hope this helps.
- moderator2
- UHM Super Moderator
- Has thanked: 154 times
- Been thanked: 560 times
Re: Howdens drawers
Ianto1959 , the thread is 5 years old. Pretty certain the OP will have fitted his kitchen by now.
I'll lock this thread in a mo.
