Free Tacwise metal stapler Z1-140
- nick200
- Has thanked: 409 times
- Been thanked: 222 times
Re: Free Tacwise metal stapler Z1-140
I have mine and used it on our log shed. It is built from whatever wood was given to me and mainly is good but got a leak recently so got a cheap tarpaulin and stapled it on. It works really well and now getting more ideas (Christmas lights sounds good!) thanks Chez.
Nick
- ultimatehandyman
- Site Admin
- Has thanked: 999 times
- Been thanked: 915 times
You are all welcome, but I only posted out the items.
Thanks to Tony from http://www.tacwise.com/ who sent me the staple guns
- big-all
- Pro Carpenter
- Has thanked: 731 times
- Been thanked: 2306 times
mines arrived today
nice well made bit off kit 6-8mm staples
wood plastic paper with ease and because you are already pushing to set the lever it goes where you put it without jumping on the recoil
the staples are the same as the staples my ryobi 18v pin and staple gun uses so no futher collection required
i also found out without reading the instructions if you pull the lever back about 2mm it will close and lock without firing a staple
when i slide the staple compartment cover back mines has a 1008 printed on the now exposed surface has anyone else a number printed there and what is it ??
- nick200
Mine says 1008 as well.
I am glad that you pointed out the pull it back 2mm as I keep firing it to close it
Nick
- big-all
- Pro Carpenter
must be a batch or machine reference number thennick200 wrote:Mine says 1008 as well.
i play with things to understand them and see how they work and if they are well designed
and i though it was a tad loose until i worked out its designed that way so hats off for a good design feature
i also like the way iff you try and close the handle in the locked position it effortlessly moves to the correct position to lock normally
i also like the easy to unclip clear plastic window on lower level off the machine so you can write you name or logo on the card to let you know its yours an no one elses's
- kellys_eye
- Has thanked: 357 times
- Been thanked: 1790 times
Not sure about the label idea - tools these days need something more permanent than a paper label to keep them your own... I'll be doing the usual burn-into-the-plastic-with-a-soldering-iron-identity-job on mine
It staples very well and I tried it on softwood, plywood, MDF and WR MDF. Each and every staple entered the wood cleanly, level with the surface and with no distortion. It also fires a staple over 5m in free air (and it bounced back off the wall the same distance!) before I read B-A's discovery of how to lock it without firing it! Ooops.
That's what you get for making the instruction sheet a tiny strip of paper printed in umpteen languages.
Other than a suspicion (totally unwarranted at this time) that the plastic parts - particularly the staple drawer - might suffer breakage the overall feel is one of sturdiness. Even Mrs k_e can operate it so that's got to be another +1 from me.
This one is a 'keeper'. Nice one Tacwise - and thank you to Tony for the generous donation
