Page 1 of 2
Does an electric oven require an isolation switch?
Posted: Tue Apr 23, 2013 5:02 pm
by gocsan
I know this must have been asked many times before, but I cannot find a good answer. Despite reading around, I get mixed views. Does an electric cooker require an isolation switch?
For your information, I have a dedicated circuit from the consumer unit just for the electric cooker, but it has not isolation switch. The only switch available is the circuit breaker from the consumer unit located under my stairs, which in my opinion is fairly accessible and is approximately within 2m of the cooker.
I've recently had an electrician inspecting my electrics and have asked him this question, do I need one of those red isolation switches above the worktop for the electric cooker and he said not really because I can use the consumer unit as a mean of isolation.
So after reading around on the internet, who is right or wrong? My kitchen hasn't been fitted yet, but I would be gobsmacked if after fitting all the cupboards/worktop and then hiring an electrician to wire the cooker, he tells me that he refuses to wire it because I don't have an isolation switch. Last thing I want to do is rip my kitchen apart to get this isolation switch installed.
Re: Does an electric oven require an isolation switch?
Posted: Tue Apr 23, 2013 5:29 pm
by ericmark
I raised the same question when my mothers kitchen was installed. The house electrics were in a real state so the installer ran a SWA feed to a mini consumer unit in the kitchen. I said no need for isolator but the contractor insisted on fitting them. He felt for the cost of an isolator it was not worth taking the chance. In fact he fitted the isolators where with a hob fire you could not operate them had there not been a consumer unit in the kitchen I would have objected to the work. But the essence is if you want to be sure then fit isolators.
Posted: Tue Apr 23, 2013 5:43 pm
by BillyGoat
and I'm sure Onlyme will agree, it needs to be within 3 metres....... :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol:
Posted: Tue Apr 23, 2013 6:13 pm
by OnlyMe
BillyGoat wrote:and I'm sure Onlyme will agree, it needs to be within 3 metres....... :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol:
Cooker isolators need to be within 2 metres :wink:
I'll take "cooker" to mean "hob"
Posted: Tue Apr 23, 2013 6:14 pm
by BillyGoat
But the rules, THE RULES!!!!
Posted: Tue Apr 23, 2013 6:15 pm
by gocsan
Sorry guys, correction, I meant electric oven. I will have a built in gas hob.
Posted: Tue Apr 23, 2013 6:23 pm
by OnlyMe
BillyGoat wrote:But the rules, THE RULES!!!!
We have rules for a reason.
They give you something to bend or break.
Posted: Tue Apr 23, 2013 6:25 pm
by OnlyMe
gocsan wrote:Sorry guys, correction, I meant electric oven. I will have a built in gas hob.
And what does the installation manual for the oven say?
I've yet to see one that does not specify double pole isolation.
Posted: Tue Apr 23, 2013 6:42 pm
by gocsan
Hmm looking at the manual it says 'In the installation, there must be an all-pin isolating switch with at least 3mm contact gap, or the appliance must be connected using a plug with an earthing contact. This must remain accessible after installation'.
Posted: Tue Apr 23, 2013 6:49 pm
by gocsan
Just moving onto a slight different topic, I'm just reading my gas hob manual as well and it says 'The hobs are supplied with a power cable with or without a wall socket plug. Appliance with plugs must only be connected to sockets that have earth wires correctly installed. Provide an omnipolar cut-off switch with a minimum contact opening of 3mm (except for plug connections, if the user has access to it)'.
My gas hob does not come with a 3 pin socket, so does that mean this also needs to be hard wired too???
Posted: Tue Apr 23, 2013 6:57 pm
by gocsan
I can't imagine a gas hob that requires hard wiring. It only needs ignition for the flame.
Posted: Tue Apr 23, 2013 7:52 pm
by darrenba
gocsan wrote:I can't imagine a gas hob that requires hard wiring. It only needs ignition for the flame.
Usually wired into a 3a Switched Fused Connection Unit
Posted: Tue Apr 23, 2013 7:54 pm
by darrenba
gocsan wrote:Hmm looking at the manual it says 'In the installation, there must be an all-pin isolating switch with at least 3mm contact gap, or the appliance must be connected using a plug with an earthing contact. This must remain accessible after installation'.
There you go then - Isolation Switch required.
Posted: Tue Apr 23, 2013 7:55 pm
by OnlyMe
gocsan wrote:Just moving onto a slight different topic, I'm just reading my gas hob manual as well and it says 'The hobs are supplied with a power cable with or without a wall socket plug. Appliance with plugs must only be connected to sockets that have earth wires correctly installed. Provide an omnipolar cut-off switch with a minimum contact opening of 3mm (except for plug connections, if the user has access to it)'.
No - It means you should wire it to a double pole switched fused spur, or plug it into a double pole switched socket or into an unswitched socket.
Posted: Tue Apr 23, 2013 8:13 pm
by John MacLeod
It's the usual problem of dealing with equipment designed for the Continental market with a translation into pidgin-English with no regard to UK wiring practices. Omnipolar cut-off switch, indeed! 3-phase supply? Hardly!
