Very confused!
- Has thanked: 1 time
Very confused!
Hi I'm new here, and looks like the best place for advice, so...
It's just a question about my hot water cylinder.
I have a boiler in the kitchen, and a hot water cylinder at the top floor in an airing cupboard. There is a control box next to the boiler, which has two red lights if either the hot water or heating is on.
The hot water light is always on (is this is a good idea?) and does this control the cylinder on and off setting?
- thescruff
- Has thanked: 360 times
- Been thanked: 3734 times
Re: Very confused!
It's a Worcester Greenstar HE System Boiler, with a Myson temperature dial, and a Myson on/off control box with timings.
- thescruff
Re: Very confused!
Can you ID them in the catalogue.
- Myson Controls Catalogue.pdf
- (5.89 MiB) Downloaded 245 times
- thescruff
Re: Very confused!
Ok It has 4 dip switches on the back, check that dip 4 is up in the pumped position.
Do you have the manual for it.
Do you also have a motorized valve and what is the make model.
Re: Very confused!
I don't know if I have a motorised valve, do you want the make and model of the boiler or cylinder?
- thescruff
Re: Very confused!
Have a look in the catalogue at motorized valves.
Have attached the manual it will tell you what the 4 switched do.
- MEP2C_Installation_Instruction.pdf
- (254.37 KiB) Downloaded 232 times
- Has thanked: 419 times
- Been thanked: 889 times
Re: Very confused!
It wont make much difference. The red light being on just means that if needed the boiler can reheat the hot water cylinder when you draw off some hot water.Jasonpikephoto wrote:The hot water light is always on (is this is a good idea?) and does this control the cylinder on and off setting?
The cylinder thermostat will turn off the boiler once the desired hot water temperature is reached, so although the red light is on 24/7, the boiler won't be.
Dave
www.drlgas.co.uk
www.drlgas.co.uk
Re: Very confused!
Do you think it will use more energy leaving it on constant or using it as of when I need it. All the hot water heats up in the tank. I've recently moved into this place and I'm just getting used to the central heating etc. I would like to know the most economical way to use the whole system, ie boiler, hot cylinder. I just use the heating when I need it.
- thescruff
Re: Very confused!
You have a fault, maybe component, maybe an installation error, maybe user error and programming.
Re: Very confused!
What makes you think there is a fault? When the hot water is turned on via the Myson programmer it makes noises every now and then, I'm guessing that's the water heating up to keep it up to the set temperature. I happens all day and all night.
What do people normally have their programmers set to?
- thescruff
Re: Very confused!
Good question, Should the led be on or not. ?
If the HWS mode is off then no it shouldn't be, whereas if the DHW mode is on it should be.
How you run the DHW depends on occupancy and the demand.
If the property is empty during the day, the norm would be a couple of hours at night and a top-up in the morning, and maybe longer at weekends.
Re: Very confused!
Oh right ok, we'll I have set it on a timer now, so it's on 2 hours at a time. But why is the cylinder still heating up? Even when it's off
