Is my previous topic on how to wire up the Honeywell CM 927 Thermostat closed now ? The last activity was early September 2012. The link for that post is this
how-to-install-a-room-thermostat-on-my- ... 78-90.html
The reason I asked this is because last Sunday, I posted a question there, but I did not get any response, which is very unusual as in the past, I tend to get a very swift response.
The question I posted there is how to wire up the existing wiring to fire up my central heating heater if the room stat should fail.
Any clarification will b greatly appreciated.
Many thanks.
My Last Topic on Wiring Up a CM927 Thermostat Closed ?
- moderator2
- UHM Super Moderator
- Has thanked: 154 times
- Been thanked: 560 times
Re: My Last Topic on Wiring Up a CM927 Thermostat Closed ?
The thread you have linked to isn't locked/closed
Most threads will be locked after a month or so of inactivity.
- Has thanked: 7 times
Noted. Thanks. So I was just a couple days before the thread is closed. :)moderator2 wrote:The thread you have linked to isn't locked/closed
- moderator2
You can always ask for a closed thread to be re-opened. Just click on the red exclamation mark at the bottom right of a post (This is the alert moderator button which can be used to report spam or to request the thread moved or to ask for a locked thread to be re-opened)
- Closed thread.JPG (23.78 KiB) Viewed 2718 times
- thescruff
- Has thanked: 360 times
- Been thanked: 3734 times
Yes but they will always unlock it, if you beg them nicely.
bit slow there scruff
Thanks. That is very useful to know for future referencemoderator2 wrote:You can always ask for a closed thread to be re-opened. Just click on the red exclamation mark at the bottom right of a post (This is the alert moderator button which can be used to report spam or to request the thread moved or to ask for a locked thread to be re-opened)
