Afternoon all
I am shortly having an extension and i am currently looking into insulations costs and the best/easiest gear to handle.
Which make and material would you advise firtsly, and how much do they cost in at please per roll/Square M2 or however they price it.
It is for both roof and wall also...
Thank you
Kingspan Insulation advice please
- wine~o
- Has thanked: 1413 times
- Been thanked: 3991 times
Re: Kingspan Insulation advice please
Building control will advise on minimum standards of insulation for an extension, Kingspan/celotex are the main brands that spring to mind.
- kellys_eye
- Has thanked: 357 times
- Been thanked: 1790 times
You're looking at £12 to £18 per sq m for celotex/kingspan type stuff depending on thickness. Sold in 2400x1200mm sheets, 20mm to 150mm thick (the prices I quote are for 100mm to 150mm).
Check out this site as an example
http://www.insulationexpress.co.uk/Insulation.htm
- Walchy01
- Has thanked: 41 times
- Been thanked: 5 times
Hi there
I am looking for some 100mm cavity wall insulation, around 140 metres in total, what sort of price will this cost? which insulation is the easiest to handle/fit, been told the Kingspan is a bit faffy cutting etc
Thanks for any help.
- inspire
- Has thanked: 1 time
- Been thanked: 35 times
ISOVER Cavity Wall Insulation is easy to handle and to fit thats the one I haveused in the past
