Hole found in roof felt in loft - is there quick fix?
- nick200
- Has thanked: 409 times
- Been thanked: 222 times
Hi all,
I hope that this is the reight place to put this?
Not sure what to do here but I went into the loft and noticed that part of the felt has a hole in (probably about an inch across) and the wood has gone white along it (does not feel wet). Is there a way to fix it so that the tiles do not need to come off and I can do it internally? Can a felt patch be cut and then a quick seal/all weather roof repair be used to secure it in place? I have attached a photo but it is not the best quality...sorry but I can go back up later if required. If possible I would like to do the work myself and internally due to financial issues but if we need to I will get someone in to get the tiles off
If the felt can be repaired internally then what is the best way to clean the wood off? Now I have read that once the wood is dry then to clean off the wood (some say with bleach solution) and then treat the wood once dry with something like Cuprinol?
Many thanks for your help.
- IMAG0751 resized.jpg (81.81 KiB) Viewed 19779 times
Nick
- BANNED
- Has thanked: 216 times
- Been thanked: 1070 times
Re: Hole found in roof felt in loft - is there quick fix?
Can you fit a section of felt, make it large enough to lap over the bottom section and tuck under the top section.
Failing that Duct tape would do a temp repair.
Theres more work involved to do it properly, ie remove tiles and battens, new bit of felt, rebatten and tile.
- These users thanked the author cotswold builders for the post:
- nick200
- nick200
Hi Cotswold Builders, thanks for your reply.
I like the idea of a felt flap, what would i use to stick it to the existing felt. At least that gives me time to save.
Thanks.
Thanks.
Nick
- Location: Worcestershire/Warwickshire/Gloucestershire (ish)
- Has thanked: 51 times
- Been thanked: 152 times
Duct tape.nick200 wrote:Hi Cotswold Builders, thanks for your reply.
How old is the house and and who built it? And is that part of the roof South facing.
I ask because I have a Wimpey built home, late 80's, where they used some material that apparently originated in Germany. And it breaks down with time, turning to powder/dust. Initially on the South facing side. Many of the houses on the estate have had to have the complete roofs off to be re-felted. I'm lucky. The house is sound but the garage is knackered but, being a garage, does it matter? Just a few MORE draughts.
And from my experience with cars, a draughty garage is actually an advantage, in that it helps to remove any rain/moisture from the bodywork that otherwise could lead to rusting.
- ultimatehandyman
- Site Admin
- Has thanked: 1000 times
- Been thanked: 917 times
A mate of mine once had a hole in his felt like that and he fixed it by applying some flash banding primer and then flash banding over the top of the hole. Flash banding sticks like sh!t to a blanket on most surfaces and sticks even better if it is heated a little- just another possibility
- These users thanked the author ultimatehandyman for the post:
- nick200
- nick200
Thanks Grumps I will go and get someGrumps wrote:Duct tape.nick200 wrote:Hi Cotswold Builders, thanks for your reply.
The house is from the 80's but not sure if Wimpey's? The roof, apart from the hole, looks fine (well I assume fine) but it is not a powder/dust. I think that a few yeas ago someone punctured it but that it was never noticed (well I hope so!).
I bet the ventilation helps with the cars, the last thing you want is a damp car going in and staying damp
Nick
- nick200
Thanks UHMultimatehandyman wrote:A mate of mine once had a hole in his felt like that and he fixed it by applying some flash banding primer and then flash banding over the top of the hole. Flash banding sticks like sh!t to a blanket on most surfaces and sticks even better if it is heated a little- just another possibility
Sounds like it should work but what is flash banding?!
Nick
- BANNED
Flash band is a silver/grey tape with bitumen on the back, available in the buiders merchants, wickes and some diy stores, normally used as a flashing alternative to lead, where roof adjoins wall.
Someone mentioned heating the tape, good idea as it makes the bitumen more pliable, and sticks better.
Be warned, dont use a naked flame, use a hot air gun or hair drier.
- nick200
- nick200
Thanks, I will attempt that soon but without flame!!cotswold builders wrote:Flash band is a silver/grey tape with bitumen on the back, available in the buiders merchants, wickes and some diy stores, normally used as a flashing alternative to lead, where roof adjoins wall.
Nick
