Plastering over ceramic tiles
- Has thanked: 6 times
Hi Everyone, I have a question to ask of the forum members. Is it possible to apply a plaster finish of approx. 2mm over ceramic tiles?
It is in a kitchen area and the only other alternative is to take all the tiles off ( approx. 20 sq. mtrs.) and then replaster.
This is a big job and would rather plaster over exist. tiles if possible, maybe with a couple of coats of PVA. What does the team think?
Many Thanks
Many Thanks
- Has thanked: 12 times
- Been thanked: 32 times
Re: Plastering over ceramic tiles
Yes, you can plaster over tiles.
Give it a coat with Wickes bonding agent, as it is better than PVA.
You can also throw a few handfuls of sand onto the bonding agent when it is wet to enable the plaster to stick better.
- These users thanked the author amarg for the post:
- squareball
- Has thanked: 1 time
- Been thanked: 12 times
just be aware that the plaster will only be bonded onto the bonding agent and not the wall thus makeing it weaker. if you wait till the bonding agent is dry then use you finger nail youll see the bonding agent hasent actually bonded to the tiles its simply dried ontop.
i personally would take the tiles off and do a proper job.
"a job worth doin is a job worth doin properly"
- These users thanked the author jrplastering for the post:
- squareball
- Has thanked: 5 times
- Been thanked: 26 times
If you are going to plaster anyway.... I would take the tiles off
- These users thanked the author mcluma for the post:
- squareball
Not the answer I was hoping for, but do get your point, what about scouring the tile surface ? Many Thanksjrplastering wrote:just be aware that the plaster will only be bonded onto the bonding agent and not the wall thus makeing it weaker. if you wait till the bonding agent is dry then use you finger nail youll see the bonding agent hasent actually bonded to the tiles its simply dried ontop.
youd be just as well to take em off mate honestly its the proper way to do it give you a nicer finish
- squareball
Won't take long to get them off with a roto stop chisel. Like the other lads say, you'll have a much better job having got them off.
- These users thanked the author All The Gear for the post:
- squareball
- Has thanked: 45 times
- Been thanked: 272 times
If you plaster the tiles, the kitchen fitter will be unable to fix to the wall withut using tile drills which they may not have. They may also crack your skim because they can bash about a bit.
They would probably tell the customer that you are a cowboy, so even if it does work, you are unlikely to get a recommendation for further work.
- These users thanked the author jozeffo for the post:
- squareball
Point made, thanks, guess I'll park my horse and take the tiles off ( my wife's been saying this all along ) but I was looking for the easy way out.jozeffo wrote:If you plaster the tiles, the kitchen fitter will be unable to fix to the wall withut using tile drills which they may not have. They may also crack your skim because they can bash about a bit.
