Bathroom ceiling
- ultimatehandyman
- Site Admin
- Has thanked: 999 times
- Been thanked: 915 times
Bathroom ceiling
Here is a couple of pics of a ceiling that I have almost finished in an ensuite bathroom.
The bathroom was artexed before and above the shower area there were mosaic tiles on the ceiling. It looks much better now.
Fitting the stud work for the planks and fitting the planks and the downlighters and the extractor was pretty easy and enjoyable, but fitting the damn beading around the ceiling was a nightmare. None of the corners were square and I am sure that my mitre saw is cutting 45 degrees one way and 46 degrees the other way
Fitting the beading on laminate flooring is much easier.
I'll post the before pictures at a later date.
- Before picture 1
- bathroom-before.jpg (24.4 KiB) Viewed 8033 times
- before picture 2
- bathroom-before1.jpg (21.45 KiB) Viewed 8033 times
- bathroom_ceiling.jpg (23.98 KiB) Viewed 8051 times
- bathroom_ceiling_1.jpg (26.12 KiB) Viewed 8051 times
- bathroom_ceiling_2.jpg (24.61 KiB) Viewed 8051 times
Last edited by ultimatehandyman on Thu Aug 23, 2007 7:41 am, edited 1 time in total.
- BANNED
- Been thanked: 1 time
- Paslode_itw
- BANNED
- yourweb
At first I thought I was looking at the floor. But than as I looked at the rest of the pics I realized this was not the case. Nice job.
There is suppose to be a trick for doing corner molding if your walls are not square. For the life of me I don't remember what it is. The only thing I can think of is that angle tool. Not sure what it is called.
- ultimatehandyman
- Site Admin
Its'mdf and coated, just like laminate flooring.tim'll fix it wrote:is it real wood ? or the upvc stuff
I have fitted the white upvc type stuff once, what a nightmare trying to lock 3m lengths together on the ceiling
the stuff I was doing was called starline ? or summat
Diy peter fitted this in his office a few posts down.
The planks are only about 1.2m in length and were pretty easy to fit, but the beading was a nightmare!
- ultimatehandyman
- Site Admin
I was using the Bosch GFS 350 E
But for some reason if I cut a 45 degree one way and then another way and put them together the joint would be out be a mm or so
Fixing beading on a ceiling is a pain in the butt as well, it's much easier on the floor!
- Hoovie
- Borders Bodger
- Been thanked: 4 times
I presume that the boards must be fixed in place and be rigid? (floating ceiling?) - if so, could you eliminate the need for a expansion gap, go close up to the wall edge, and then have the wall tiles cover any gap in the same way skirting would on a floor?ultimatehandyman wrote: Fixing beading on a ceiling is a pain in the butt as well, it's much easier on the floor!
- ultimatehandyman
- Site Admin
- Hoovie
- Borders Bodger
very smart indeed - looking for a solution for my bathroom - lath and plaster ceiling (and walls ) and inside the airing cupboard it is totally shagged - and as airing cupboard coming out, not sure what to do (I cannot plaster to save my life)
either clad it or get a man in!
BTW - Downlighters look well good - where did you get them?
- ultimatehandyman
- Site Admin
That type of ceiling is easy to fit, but the beading is difficult and it made it harder by setting up the saw in the garage and so for each piece I had to walk to the garage and then open the door etc. I'll post a tutorial soon on how to fit the ceiling, I wish I could remember the name of the stuff lolHoovie wrote:very smart indeed - looking for a solution for my bathroom - lath and plaster ceiling (and walls ) and inside the airing cupboard it is totally shagged - and as airing cupboard coming out, not sure what to do (I cannot plaster to save my life)
The downlights were the cheap ones from screwfix and are all 12v, the one in the shower is a fan with halogen lamp in the middle, again all 12v.
- Hoovie
- Borders Bodger
Thanks - I fitted some downlights (cheap ones from Wickes) in my last bathroom, but I think they would now not pass current regs and also went rusty within a couple of years
- ultimatehandyman
- Site Admin
- Hoovie
- Borders Bodger
Don't think the ladies like flourescents too much - too much becomes visible!
Here is an interesting alternative to normal downlighters- http://www.screwfix.com/app/sfd/cat/pro ... 7&id=42771
IP66. 12V. 40mm diameter LED Kit with IP66 rating for indoor or outdoor use. 4 fittings supplied, each containing 8 super-bright LEDs. Extendable with Add-on Kit.
5m cable per fitting, 10-way master junction box with 10m cable, 8 super bright LEDs per fitting
