Intergas 24/18 HRE compact Combi
- thescruff
- Has thanked: 360 times
- Been thanked: 3734 times
Re: Intergas 24/18 HRE compact Combi
What is the relation between Intergas and the atmos intercombi.
Are they same model re-badged.
- Mehran2
- Has thanked: 6 times
- Been thanked: 39 times
the atmos one is the older less efficient heat exchanger design but in essences its the same idea so lime should in theory affect them in the same way.
- thescruff
Which in your opinion is the better of the two, or are they on a par.
- Has thanked: 29 times
- Been thanked: 149 times
That does not make sense! How can the radiator be hotter than the flow temperature?thescruff wrote:At the moment I have roughly 62 flow and 42 return.
Checked all the rads and average is 80c.
- Mehran2
the intergas is better,the boiler is more efficient, smaller, longer flue lengths and has designed out a problem with the drain that the older types had. the negative side it made the flue off centrer and has an external expansion vessel
- thescruff
No idea Dave, I wondered that as well.D Hailsham wrote:That does not make sense! How can the radiator be hotter than the flow temperature?thescruff wrote:At the moment I have roughly 62 flow and 42 return.
Currently the fittings on the boiler are recording 68/53 the rads are 82. with a digital thermometer.
- Mehran2
I did not want to say as I though you were having another senior "moment"
I uses: these
I uses: these
- thescruff
I have clamp on pipe stats I'll try them later.
The return could be put down to heat loss through the cold area, but not the flow.
- Has thanked: 2 times
- Been thanked: 6 times
You can thank Atmos for that! They told intergas no until we hounded them mercilessly! in fact intergas asked us to write to them as they have a lot of respect for the Gaff hereMehran2 wrote:btw would this be a bad time to say that intergas approved installers are going to be able to give 5 year warranty on boiler...so I have just been told...
From experience we've found the "not a problem" attitude is a little unwise. We too were told that scale wouldn't be a problem and it is arguable that it is less likely to scale than plate hx with it's thin water ways. It is also true that the design helps to "flush" scale through. However as you all well know if you put a device in a hard water scale will come to some degree! As it mentions in the previously posted doc scale inhibitors help, seemingly different ones seem to perform to varying degrees of success depending on where they are in the country. Ultimately if you really want to solve scale you need to fit a water softener!Mehran2 wrote:just had a quick look in the intergas manual, the only reference I can find about lime scale is in the fault finding tables telling you to de-scale if it scales up... did not find anything saying you have to fit a scale reducer.
an over sight maybe?
I did get the impressing of 'nothing to worry' about when I was at intergas HQ. was also told that Holland has hard water as well...
- thescruff
Not another flood
Just discovered the old washing machine hose doesn't like mains pressure.
At least the radiators are holding up for the moment.
- EJJ150847
- Has thanked: 35 times
- Been thanked: 188 times
thescruff wrote:Not another flood
Get a proper Plumber in quick before you flood your self out
John
- thescruff
It's quite interesting John, to count all the eventualities when changing from a low pressure system to a high pressure one.EJJ150847 wrote:thescruff wrote:Not another flood
John
Shower valve don't like it.
Old washing machine hoses split.
Radiator valve seem to be ok, as does the old pipe work and radiator.
Removing the cylinder, meant I had to swap the hot over as well as the tank cold to the shower etc.
Think I'll start turning the water off when I go out
One of the computers is ok it's a MAC.
- Razor
- Has thanked: 483 times
- Been thanked: 1251 times
Wc inlet valves already off the mains then
- thescruff
Yep.Razor wrote:Wc inlet valves already off the mains then
There's quite a list of possible extra's if one to price for the job.
