Hello,
Is there any minimum space required between pattress style double sockets?
I can't recall anything but just wanted to check with the changes that have taken place.
Socket Spacing? What if any
- Jaeger_S2k
- Pro Handyman
- Has thanked: 20 times
- Been thanked: 27 times
- sparkydude
- Has thanked: 2 times
- Been thanked: 149 times
No Rules if they are mounted on surface boxes, not between anyways, but there is as to distance from floor, it must be far enough up so as to not put a strain on the flex in the plug which in reality means do not mount the box just above the carpet.
Nick
Nick
- sparkydude
- Jaeger_S2k
- Pro Handyman
PHEW!
Thank the wee man for that. I didn't think there was but just as I put the last one up and wired I thought???????????????
Set at 450 mm Min.
Set at 450 mm Min.
Yeah, as the Architects will tell you it's to make it easier for them to tangle the trailing flex round the wheels.skiking wrote:I thought there was a minimum height rule now to help wheelchair bound people. Basically sockets have to be 2-3ft up from the floor.
Jaeger.
