Cutting skirting boards
- Has thanked: 177 times
- Been thanked: 2 times
I had to cut six existing skirting boards today that were already on the bottom of the wall. Took quite a while because of the awkward angle. Are there any specific tools that can make an easier job of that?
- Argyll
- Has thanked: 1168 times
- Been thanked: 571 times
Multitool?
- arco_iris
- Has thanked: 184 times
- Been thanked: 535 times
Any multitool.
Without making any recommendation, I post this video solely because, at 2 minutes 40 seconds approx., it shows cutting a skirting board.
- Has thanked: 775 times
- Been thanked: 3314 times
Just add that it is worth spending a bit of time scribing the proposed cut lines with a knife and square. This allows the plunge saw blade to locate in the groove to keep the cut straight. I have used a block of wood screwed to the board as a guide as well as I find it a bit difficult to keep the tool cutting straight due to the vibration. I might just be a Larry limp wrist though.
- These users thanked the author dewaltdisney for the post (total 2):
- _Chris_ (Wed Jan 13, 2021 5:55 pm) • London mike 61 (Wed Jan 13, 2021 6:16 pm)
- Rating: 14.29%
- Has thanked: 61 times
- Been thanked: 184 times
Your not alone, I find the blade wanders on a flat surface. Never thought to scribe tho, will do in the future.dewaltdisney wrote: ↑Wed Jan 13, 2021 10:12 am I find it a bit difficult to keep the tool cutting straight due to the vibration. I might just be a Larry limp wrist though.
ah
- Has thanked: 6 times
- Been thanked: 187 times
OP why not post a photo ?
Its sometimes best plan to remove the whole length of skirting and then make the cuts. Then, if you have one, you can use a mitre saw etc.
You definitely have to remove a length to cut a scribe.
- Argyll
If you mark it with a stanley knife rather than a pencil the blade cuts a lot better. It follows the least path of resistance. I rarely use a pencil for marking now I often use a stanley blade.dewaltdisney wrote: ↑Wed Jan 13, 2021 10:12 am Just add that it is worth spending a bit of time scribing the proposed cut lines with a knife and square. This allows the plunge saw blade to locate in the groove to keep the cut straight. I have used a block of wood screwed to the board as a guide as well as I find it a bit difficult to keep the tool cutting straight due to the vibration. I might just be a Larry limp wrist though.
Oops DW beat me to it
- Argyll
if you don't use it that much just buy a corded one. They're a lot cheaper. You should find one on FB Marketplace/Gumtree at the moment as people received cordless ones from Santa.
