Angle grinders 115 / 125mm
- Has thanked: 118 times
- Been thanked: 21 times
Been using my angle grinder loads lately, in fact it's my current no. 1 favourite tool
So many uses and even using it to cut wood with a new fancy Bosch carbide blade (just trimming stuff of course, not chopping up logs or anything!)
Anyway I'm considering an upgrade to a 125mm (from current 115mm). I guess the bigger blade will make a small difference to performance, but the upgrade would also include a brushless motor which should improve both power and, more importantly, battery life. My current brushed 115mm grinder just gobbles up the batteries.
Might be an ideal prezzie to ask for from Santa, but anyway my question is this:
Can I use 115mm blades on a 125mm machine? I have a fair number of 115 blades sitting around and would ideally like to use them up, what with being a bit of a tight git and all.
Looks like all the standard blades in both diameters have a centre bore of 22.23mm, so I''m thinking they should be interchangeable unless I'm missing something?
Can anyone please confirm?
Cheers
Cheers
- Has thanked: 99 times
- Been thanked: 1022 times
Should be the same size fitting, I have 125mm grinders and use smaller blades all the time.
- big-all
- Pro Carpenter
- Has thanked: 731 times
- Been thanked: 2305 times
you will get slightly less blade protection with a smaller blade/disk but as the blade is very open in use it wont make any real extra danger
it will be worth measuring the visible blade on each machine although a very small difference in size the new machine may have a bigger body so less visible blade or indeed a smaller body so you wont know without a measure
- Job and Knock
- Old School Chippie
- Has thanked: 742 times
- Been thanked: 1572 times
Yes, but if you think about metal and stone cutting discs, B-A, they reduce in diameter as they are used in any case.
Also for the multi material cutting disc (which I presume is the one the OP is referring to), because it is a fixed size disc, looking a lot like a diamond coated segmented masonry disc, it won't reduce in diameter, so the gap between the edge of the disc and the guard will be an extra 5mm, which the guard should accommodate
The really dangerous cutters are those carbide tipped saw blades the Chinese produce - on an angle grinder they are simply an accident waiting to happen
- These users thanked the author Job and Knock for the post (total 2):
- Croker (Fri Nov 27, 2020 7:59 am) • big-all (Fri Nov 27, 2020 12:04 pm)
- Rating: 14.29%
Thanks for your replies, I suppose it’s common sense really that they’ll fit and work fine but it’s good to have confirmation anyway.
Come to think of it I was sorting out my blades recently and one diamond edged blade that has seen considerable (ab)use is tiny now. Reckon I’ll still get some more mortar out with it before it goes in the bin though!
The Bosch carbide blade I was on about is indeed a multi material fixed size disc (highly recommended btw, and on offer at Tool Station at the moment £7.98 for a 115mm).
Haven’t come across any angle driver saw blades but can well imagine they exist. No way would I use one, our nearest A&E is about 15 miles away!
- Job and Knock
In fact it can be handy to keep a couple of small abrasive wheels for the odd time when you can't get a new, full size wheel onto a tight spot
They are all Chinese AFAIK and have pretty much disappeared from the market, thank goodness (and trading stsndards), but there are still a few outfits selling them. There was a guy over on another forum who converted his angle grinder to use a circular saw blade - then died when it kicked back in use and severed a major blood vessel. Grinders need to be treated with respect because they have so much potential for injury - strapping a wood saw blade on one seems just plain bonkers(no base, no riving knife so no way to limit kickback)
- Razor
- Has thanked: 483 times
- Been thanked: 1251 times
I used to have an arbortech wheel with three carbide teeth. It was a great demolition tool but scared the crap out of me everytime I used it.
Even a 5" wheel has some serious gyroscopic effect at that speed!
- Has thanked: 32 times
- Been thanked: 786 times
some people should have tools taken off them.
messing about with blades the machines are not designed for is a recipe for disaster in even the most experienced hands
- ayjay
- Has thanked: 458 times
- Been thanked: 1708 times
I've done it round the other way with a metal cutting disc in a circular saw when I had a lot of EML to cut up.
I didn't own an angle grinder at the time, and the discs were just lying around waiting to be put to use.
bloke i used to work with went to adjust the guard on his 9 inch grinder... he did it when the blade was still slowing down. cut a 3mm ish wide chunk out of his wrist haha the dafty
- Job and Knock
[url]
Skilsaw still sell the Mag77 framing saw in the USA as being suitable for cutting sheet metal, with either a metal cutting blade or a grinding disc. Those saws certainly have sufficient weight to be stable, as well as sufficient torque to deal with cutting up profile steel cladding, roofing, etc
Stumpy nubs on youtube has a very good video about his angle grinder/carving blade accident.
- These users thanked the author Rorschach for the post:
- Job and Knock (Sat Nov 28, 2020 5:45 am)
- Has thanked: 1299 times
- Been thanked: 1175 times
I remember those Arbortech blades coming out, but I never really fancied one much.
Mate gave himself quite a bad cut on the leg with a 9" angle grinder.
He'd never used one before. 'Nuff said.
- These users thanked the author Dave54 for the post:
- Job and Knock
The name preceded the accident but yes very apt. I don't think he lost any fingers but it was really nasty.
