Hi guys,
I was bought a torque wrench as a present but it's for 1/4 sockets. The sockets I have all seem to be mainly 1/2 inch.
I know you can get adapters for 1/2 wrenches to use 1/4 sockets (going down a size) but I need to go up from a 1/4 wrench to 1/2 sockets. Seems a shame to buy a whole new socket set for 1/4 when I have a lot for 1/2.
Anyone know where/if I can get one?
Thanks,
Beav
1/4 to 1/2 Adapter
- Has thanked: 77 times
- Been thanked: 335 times
1/4 to 1/2 Adapter
Does your torque wrench go up high enough to torque up anything you'd use 1/2" drive sockets on?
M8 bolt (13mm soccket) will likely be ll the torque wrench is up to.
Deffinately can get adaptors, from virtually anywhere.... even Amaz....or eb....
- Has thanked: 26 times
- Been thanked: 3 times
1/4 to 1/2 Adapter
It will be used mainly for bicycle stuff. I have allen key adapters which fit the 1/2 socket. Smaller stuff i'm sorted as the 5mm etc allen key sockets fit the 1/4 inch :)
- aeromech3
- Has thanked: 177 times
- Been thanked: 650 times
1/4 to 1/2 Adapter
Might have to use 2 from this set, go amazon with this B07KXS636R.
Or this one B07G6ZB9FD.
Rolson do a set but don't seem to be good metal!
