Table Saw advice
- big-all
- Pro Carpenter
- Has thanked: 731 times
- Been thanked: 2309 times
Table Saw advice
that wing nut/lever is a shocking design as soon as you cant push carefully in a controlled fashion down 'towards the fence and forward you then have the effect off leverage far end holding the wood loosely under the lever bouncing uncontroled even if its on the otherside
- Has thanked: 61 times
- Been thanked: 184 times
Table Saw advice
It's only an issue on thin cuts, in that case why not have the wide part against the fence and thin strip to the other side as intended.big-all wrote: ↑Wed Oct 14, 2020 3:26 pm that wing nut/lever is a shocking design as soon as you cant push carefully in a controlled fashion down 'towards the fence and forward you then have the effect off leverage far end holding the wood loosely under the lever bouncing uncontroled even if its on the otherside
ah
- big-all
- Pro Carpenter
Table Saw advice
not saying its a bad saw just there are much better solutions
