Another tool dies
- Has thanked: 1299 times
- Been thanked: 1175 times
Another tool dies
I think I might have a look at one of those as well. As you say Walt, the cable is a PITA on the corded ones. Especially when I only use it for a few seconds mostly.
Another tool dies
I'll bet you'd just fitted a new blade as well?
It usually goes that way. It never seems to be one that's due to be changed anyway.
- Has thanked: 775 times
- Been thanked: 3314 times
Another tool dies
It is frightening when a band saw blade goes, I had one snap a few years ago and the broken end whipped around for a second.I jumped back quick I can tell you
Another tool dies
TBH, as long as the guarding is properly in place, the fact that one going makes you jump is probably more likely to cause an accident than a blade going. Had a few go, but mostly I'd change them long before they went, as I needed accuracy for deep cuts, and worn blades don't do that.
I used to pass 'em over to my mate for cutting his firewood.
- Has thanked: 94 times
- Been thanked: 857 times
Another tool dies
It didn't snap (i have had one go tho) it took the tip off every tooth - blades are £15-30 1715mm x 1/2" I have been looking at Axminster tools Excalibur blades
Another tool dies
On woodworking machines it's a device which ensures that the user can continue to count up to ten without removing boots and socks Walt.
