Which Makita Drill?
Which Makita Drill?
I'm looking at getting a new drill and have narrowed it down to between 2 ..... both Makita as that's what I have batteries for.
It's either the DHP482z
https://www.powertoolworld.co.uk/makita ... ofug8q1nh3
which seems like a general middle of the road drill
OR the DHP458Z
https://www.powertoolworld.co.uk/makita ... -body-only
I'm just general DIY and putting up a few shelves although I am getting into it a bit more so likely to take on bigger but not huge projects over time.
The 458 is obviously more capable and offers some future proofing but I probably won't be doing that much heavy duty work and it's biggest use will most likely be as a screwdriver.
I wonder if the 458's overkill for me and not sure of you can take the side arm off but would probably find it gets in the way / is cumbersome and is generally heavier which may be frustrating .... especially if using it as a screwdriver most of the time.
Be interested to hear what other people's thoughst ar and which they'd get for this type of use.
OR the DHP458Z
- ayjay
- Has thanked: 458 times
- Been thanked: 1708 times
Which Makita Drill?
The 482 has metal gears (which would swing it for me) and is perfectly capable of driving screws. The 485 only says "two speed gearbox", no mention of metal gears.
Which Makita Drill?
That made e google the other one with metal gears and found this on their Aussie site ... would have thought they'd be the same there and here but it's definitely a good point!!
- Has thanked: 32 times
- Been thanked: 788 times
Which Makita Drill?
not that it matters a jot here.... i have dewalt gear. i have 2 dewalt drills one is the older style brushed motor and 2 gears the other newer style brushless and 2 gears. both suit me perfect as a joiner. my mate has the 3 gear brushless dewalt drill. its canny big. heavy and cumbersome. i cant stand the thing. if it were me id possibly just go with the cheaper lighter drill.
or maybe even consider one of the smaller twin packs if makita do them?
- Cannyfixit
- Has thanked: 102 times
- Been thanked: 183 times
Which Makita Drill?
For general diy I would opt for the twin packs as Fin suggests, these come with an impact driver as well as a drill
- big-all
- Pro Carpenter
- Has thanked: 731 times
- Been thanked: 2309 times
Which Makita Drill?
how old are the batteries you have and what ah are they ??
sometimes a full kit can give you greater flexibility
Which Makita Drill?
fin wrote: ↑Mon Sep 21, 2020 6:32 pm not that it matters a jot here.... i have dewalt gear. i have 2 dewalt drills one is the older style brushed motor and 2 gears the other newer style brushless and 2 gears. both suit me perfect as a joiner. my mate has the 3 gear brushless dewalt drill. its canny big. heavy and cumbersome. i cant stand the thing. if it were me id possibly just go with the cheaper lighter drill.
Cannyfixit wrote: ↑Tue Sep 22, 2020 8:39 am For general diy I would opt for the twin packs as Fin suggests, these come with an impact driver as well as a drill
I've only just looked up what twin packs are and yes that'd be a great idea although the Makita ones all seem to come with either batteries or charger or both so it's more economical to buy them individually which as a shame as I've only fairly recently bought the batteries, charger, chainsaw and circular saw and they do all sorts of combo's which would have been great and probably saved me quite a bit as well!!!
When would you use the impact driver over the combi drill ... I'm guessing as the screwdriver ... I may possibly take a change of direction and go for an impact driver now (b'day list) and "limp on" with my current drill (battery will last a lot longer if only doing 1 of teh 2 jobs) and upgrade that at Xmas.
Which Makita Drill?
Literally 2/3 months old and 5.0amp .... noticed quite a few of teh twin packs were 10.8v or 12v as well and mine are 18v.
- big-all
- Pro Carpenter
Which Makita Drill?
ok your sortedWitterings wrote: ↑Tue Sep 22, 2020 11:25 amLiterally 2/3 months old and 5.0amp .... noticed quite a few of teh twin packs were 10.8v or 12v as well and mine are 18v.
- Cannyfixit
Which Makita Drill?
yes they drive screws in a lot faster than a combi drill ,for example ive just fitted some sleepers in a garden and 6inch screws went in in around 5 seconds.i would advise you buy the impact rated screwdriver bitsWitterings wrote: ↑Tue Sep 22, 2020 11:24 am When would you use the impact driver over the combi drill ... I'm guessing as the screwdriver ... I may possibly take a change of direction and go for an impact driver now (b'day list) and "limp on" with my current drill (battery will last a lot longer if only doing 1 of teh 2 jobs) and upgrade that at Xmas.
- Has thanked: 88 times
- Been thanked: 79 times
Which Makita Drill?
I have the 458. Brilliant kit. Glad I bought it. Yes the side arm is removable. Remember that if you ever need to use wide cutting bits like hole saws, you'll need a stronger drill, so for all round versatility, the 458 is excellent.
I've had mine for 7 years now.
I recently got an impact driver (from Lidl ) and it is excellent.
If you can afford both the 458 and an impact driver then that would cover you really well.
- These users thanked the author sammy.se for the post:
- Job and Knock (Sat Sep 26, 2020 6:04 pm)
Which Makita Drill?
I was thinking about this overnight and sort of came to the same conclusion as longer term I'll definitely get both in which case the extra size / weight of the drill isn't an issue as the smaller lighter impact driver will be doing the majority of the day to day work where something larger may be a pain and I have the extra headroom in the drill if I ever need it.sammy.se wrote: ↑Wed Sep 23, 2020 5:13 am I have the 458. Brilliant kit. Glad I bought it. Yes the side arm is removable. Remember that if you ever need to use wide cutting bits like hole saws, you'll need a stronger drill, so for all round versatility, the 458 is excellent.
Cheers for everyone's help and input .... much appreciated !!!
