Skill saw
Skill saw
Hi all. I'm after a new skill saw but having trouble deciding.
Can I ask you good fellows for your recommendations.
I mainly want it for trimming doors but obviously want a nice neat cut, one that won't chip these oak veneered doors.
Cheers.
Cheers.
- big-all
- Pro Carpenter
- Has thanked: 731 times
- Been thanked: 2309 times
Skill saw
do you mean shooting a door in[cutting to the opening ]
or trimming for new flooring ??
the dewalt plunge /track saw can cut in situ and take a minimum off 12mm off
- Has thanked: 10 times
- Been thanked: 194 times
Skill saw
I use my DW track saw for trimming and sizing doors, not cheap but it does the job properly as I am sure the other ones from the Likes of Makita, Festool ect will also do , but all expensive.
No comments on the cheaper makes , many reviews around that can shed light on all of these products.
- Razor
- Has thanked: 483 times
- Been thanked: 1251 times
- big-all
- Pro Carpenter
Skill saw
i am talking about the door in situ with the saw guard face rubbing on the floor
so gaurd and gap to blade about 9mm plus blade thickness about 2.5mm
- Has thanked: 283 times
- Been thanked: 397 times
Skill saw
A track saw is probably the best way to go but in the past when I had to trim some doors I used a evolution saw with a multi purpose blade and clamped a straight edge to the door. I put masking tape on both sides of the door with my line marked on it and set the blade to the waste side of the line.
It worked well and I did 5 doors that way without any damage to the oak veneer.
I only took off about 5 or 6mm from each door and didn’t rush the saw.
Mike
Mike
Skill saw
Thanks for the replies everyone. Food for thought. I'm only small time Handyman so budget not massive. £150-200.
So less teeth on the blade is better? I always thought that more teeth would make a smoother cut. Still learning. Lol
- Razor
Skill saw
Its probably because Fin uses a Festool which are known for bring a little anaemic
Not a problem with a Mafell but not cheap either.
If I was you I'd see what deal you can get on a Makita, Bosch or DeWalt they are all good value saws
Skill builder did a good series on YouTube where they tested loads then did a mega review
- Razor
Skill saw
All sorts tested from the cheapest up. If you like the look of any of them they have individual reviews on the channel
- big-all
- Pro Carpenter
Skill saw
definately more teeth i only use 48 and 60 teeth on my plunge saw
the solution if it struggles is set it to half depth then second pass full depth plus 2mm so the blade cuts in a forward direction with with no back off blade downward drag [plunge track saws only as they rotate in reverse]
- big-all
- Pro Carpenter
Skill saw
as an aside
you can use sacrificial 6mm board on both faces to stop break out
if you are using a track saw you need to be aware the track can grip the 6mm board well but the 6mm can move against the door
