SDS Drill no hammer function.
I would appreciate any advice re the following. My Titan SDS drill has lost the hammer function ( the drill function is ok ). Having looked inside, the piston appears to be working normally and the O rings on both the piston cylinder and the striking cylinder look ok. I replaced the recommended amount of grease but still no hammer action. Any ideas ? Many thanks in advance.
- Has thanked: 283 times
- Been thanked: 397 times
If you bought it at Screwfix then take it back for a replacement, they don’t normally argue about a swap.
Mike
Mike
- Someone-Else
- Has thanked: 42 times
- Been thanked: 2487 times
Daft that it sounds, have you got it on hammer? my one doesn't always engage
- Has thanked: 94 times
- Been thanked: 857 times
It will be the cam or something to do with the selector, the titan brand can be hit and miss it can last years or days its also rebranded under other names like Rockwell and Bauker
Spares wise I have used these a few times (Metabo bandsaw parts last order)
https://www.solenttools.co.uk/parts-by-brand/titan.html
Thanks for the reply. Forgot to mention, its' outside the warranty.London mike 61 wrote: ↑Sun Sep 13, 2020 5:45 pm If you bought it at Screwfix then take it back for a replacement, they don’t normally argue about a swap.
Mike
