Grease Advice
- Has thanked: 775 times
- Been thanked: 3317 times
Grease Advice
I opened my Echo hedge clipper drive box expecting to see white lithium grease. Whats is in there is dark and I am not sure if this is from use or if I can use the grease I have which is this https://www.carlube.co.uk/product/moly- ... isulphide/ to top it up. The existing grease is packed around the edge of the case and it is quite dense.
It lubricates the reciprocating motion of the two clipper blades so I am thinking it will be okay as it says it sustains heat, not that it gets that hot after prolonged use.
I have no experience in these matters so any guidance appreciated.
- Has thanked: 100 times
- Been thanked: 1022 times
Grease Advice
Your grease is probably much better than they used originally.
- These users thanked the author Rorschach for the post (total 2):
- Dave54 (Fri Sep 11, 2020 3:07 pm) • dewaltdisney (Fri Sep 11, 2020 3:55 pm)
- Rating: 14.29%
- Has thanked: 1299 times
- Been thanked: 1175 times
Grease Advice
That's what I think.
TBH, I use what's in the gun, usually moly, unless it's something super critical, like, er, like something super critical.
I think I've said before, my petrol hedge trimmer's years old and still going strong. Gets a couple of pumps of grease every use.
- These users thanked the author Dave54 for the post:
- dewaltdisney (Fri Sep 11, 2020 3:54 pm)
Grease Advice
Great, so as I have the cover off shall I just add a blob and spread it evenly to fill the housing or just smear the moving bits?
Grease Advice
With things like that, that are in a "gearbox" I usually do sort of both. Put some on the specific areas that actually need it, and then add a general blob over the works, but not enough to overfill the casing. That way you'r reasonably sure that there is lube where it's needed, and a bit extra that'll work in as the thing's running.
It's basically what was done with the big stuff in industry, and it's always worked OK for me.
Cleanliness is important as well. You obviously don't want to put dirt in with the grease.
Grease Advice
Thanks Dave, I see. I am probably being a bit over-cautious as the reciprocating action causing the blades to clip is quite intense. I will have another look inside after a bit of work to see how it is going I think. Now I have my socket drives it is a two minute job. I always spray the blades with WD40 after use and 3 in 1 over winter.
Grease Advice
I'm sure it'll be fine mate. Lube being in there on the mechanism and not dried out is the main thing. I've looked in lots of power tool gearboxes over the years, and the only one I can remember being dried out was my ELU belt sander. IIRC it actually says it wants checking every so many hours, and I forgot!dewaltdisney wrote: ↑Fri Sep 11, 2020 4:47 pm Thanks Dave, I see. I am probably being a bit over-cautious as the reciprocating action causing the blades to clip is quite intense. I will have another look inside after a bit of work to see how it is going I think. Now I have my socket drives it is a two minute job. I always spray the blades with WD40 after use and 3 in 1 over winter.
Scrap one gearbox, but then they run quite warm.
I do the same with my hedge cutter. Spray it. Again it's worked OK doing that over the years.
- dewaltdisney (Fri Sep 11, 2020 5:19 pm)
Grease Advice
WIth closed gearbox type arrangements I like to go for a 2/3rds fill. This means that there isn't so much in that it will lock up (a potential issue with too much grease) and there space for it to move around. Bit it also solves the problem of when you half fill it and the grease gets pushed to unused half and doesn't do any good, I see this all the time in angle grinders, gearbox half full of grease but none on the actual gears.
- dewaltdisney (Mon Sep 14, 2020 7:47 am) • Dave54 (Mon Sep 14, 2020 12:40 pm)
- Rating: 14.29%
Grease Advice
I did just that I gave a good blob of grease directly on the moving bits and a little bit more in the voids. I avoided overdoing it as Dave suggested so it does have room to move. I will check it out again before winter storage but I have a fair bit of work to do in the next few weeks and wanted to make sure it was well lubricated.
