hi, im in need of two miniature bearings,no problems there. my question is do you use a shaft with the exact i,d of the bearing and what is the best way to fit them without the proper tool?
thanks for any advice
BEARINGS
- Has thanked: 94 times
- Been thanked: 857 times
BEARINGS
bearings should be a tolerance or engineering fit
If you are making something custom turn the shaft to fit the bearings, having played with vintage engines other items don't cheap out on bearings I tend to stick with SKF or Timken
Google simply bearings
- big-all
- Pro Carpenter
- Has thanked: 731 times
- Been thanked: 2309 times
BEARINGS
we have no context here so difficult what to suggest
we need to know size[model car real car router or big machine] 'load expected performance needs
some are bolted on some are captive some are friction
some are sealed some are greased
just realized you said miniature so no heat in fitting
