hairline crack reappears
- Has thanked: 8 times
i had a hairline crack in my ceiling, which i extended to about 1cm which i thought would be enough, but upon filling the crack and sanding, the crack has reappeared. is this likely to be due to me not having made the crack bigger or something else?
- IMG_20200830_155349.jpg (45.08 KiB) Viewed 1821 times
- IMG_20200830_155355.jpg (76.49 KiB) Viewed 1821 times
- big-all
- Pro Carpenter
- Has thanked: 731 times
- Been thanked: 2305 times
what above is it a room or attic has it been used since you filled ??
- Has thanked: 6 times
- Been thanked: 187 times
What size screws, at what centres, have been used to fix the ceiling?
Is the ceiling plaster board or plaster laths?
Has the ceiling previously been overboarded?
Are the loft/ceiling joists bare with no flooring or storage on them?
Do you know the section size of the joists and their span?
