Excel Plunge Saw
- Has thanked: 20 times
- Been thanked: 12 times
Excel Plunge Saw
I've been told I should get a track saw. I don't actually need one at the moment but I can forsee circumstances where it might be very useful. My thinking is that I'd wait until I could justify getting a really good one ( prob Makita ) with a long enough set of rails to reliably cut a stock sheet of ply longways.
However, I must admit I'm slightly intrigued by this
https://www.tools4trade.co.uk/excel-165 ... -240v.html
Have any of you got any experience of Excel tools? ( esp track saws )
- big-all
- Pro Carpenter
- Has thanked: 731 times
- Been thanked: 2309 times
Excel Plunge Saw
tools 4 have been plugging excel recently so either a new to them or own brand range so cant help but suspect a new range so no feed back but just a guess
- ayjay
- Has thanked: 458 times
- Been thanked: 1708 times
Excel Plunge Saw
If you already have a circular saw, it's perfectly simple to cut a sheet of ply straight by clamping a straightedge on top and running the saw along it, the only difference from a track saw is where you place the straightedge: you'll need to make allowance for the distance from the edge of the saw to the appropriate side of the blade (once you've established those figures, write them on the saw with a sharpie).Graeme from Tod wrote: ↑Mon Aug 24, 2020 3:50 pm I've been told I should get a track saw. I don't actually need one at the moment but I can forsee circumstances where it might be very useful. My thinking is that I'd wait until I could justify getting a really good one ( prob Makita ) with a long enough set of rails to reliably cut a stock sheet of ply longways.
- These users thanked the author ayjay for the post:
- Graeme from Tod (Mon Aug 24, 2020 10:25 pm)
- Has thanked: 100 times
- Been thanked: 1022 times
Excel Plunge Saw
If going with an off brand tool I can recommend the Parkside tracksaw from Lidl, it's very good and very cheap.
- These users thanked the author Rorschach for the post:
- robgul
- Been thanked: 5 times
Excel Plunge Saw
or the McAllister from Screwfix for £99 - with 2 x rails that connect together
- These users thanked the author robgul for the post:
- Graeme from Tod (Mon Aug 24, 2020 10:26 pm)
Excel Plunge Saw
I have a circular saw which I use with either a Parkside clamp-on straightedge or a stock sheet length guide I made myself which the saw blade runs flush with. These work fine but I can't help thinking that a track saw would be more convenient if I was doing a lot of cuts. The plunge action might be helpful as well.ayjay wrote: ↑Mon Aug 24, 2020 4:56 pm If you already have a circular saw, it's perfectly simple to cut a sheet of ply straight by clamping a straightedge on top and running the saw along it, the only difference from a track saw is where you place the straightedge: you'll need to make allowance for the distance from the edge of the saw to the appropriate side of the blade (once you've established those figures, write them on the saw with a sharpie).
Excel Plunge Saw
Yes I know. One of the things that interested me about the Excel was that you could get nice long 1.5m tracks for it:
https://www.tools4trade.co.uk/accessori ... e-saw.html
I think having to fit together the very short sections of track available for some of the lower end track saws would probably wind me up. I'd feel sorted with a couple of 1.5m sections.
- Has thanked: 61 times
- Been thanked: 184 times
Excel Plunge Saw
This Excel looks like a generic clone similar to the draper / titan / workzone / parkside.
My suggestion if you are not in a hurry is watch for the lidl / aldi offers and pick one up then. I paid extra (via the manufacture) for extra tracks so now I have one permanently setup at 2.1m length. I think I paid less than £40 for 4 x 700mm tracks delivered DHL from Germany.
ah
ah
- These users thanked the author ahfix for the post (total 2):
- Rorschach (Tue Aug 25, 2020 6:04 am) • Graeme from Tod (Tue Aug 25, 2020 11:36 am)
- Rating: 14.29%
Excel Plunge Saw
For small jobs I run my parkside on it's supplied tracks. For longer cuts I bought a Festool 1.4m track on offer, this is the track i use the most I reckon. For really long cuts I can add the tracks together so I have 4 lengths available to me, 700, 1400, 2100 and 2800mm. Admittedly the 4 pieces joined together is unwieldy and not going to be as accurate as a single 2800 track but it will get the job and it good enough for my needs.
- Graeme from Tod (Tue Aug 25, 2020 11:36 am)
- robgul
Excel Plunge Saw
Which manufacturer was that for the extra tracks please - and any other details appreciated. Thanks.ahfix wrote: ↑Tue Aug 25, 2020 6:01 am This Excel looks like a generic clone similar to the draper / titan / workzone / parkside.
ah
Before I had my track saw (McAllister) I used an ancient B&D Pro circular saw with an Axminster board clamp/straight-edge as a guide rail - as suggested, mark the blade to edge plate distance and it works . . .but not as good as the track saw for the quality/break out on the cut.
- Has thanked: 775 times
- Been thanked: 3317 times
Excel Plunge Saw
I suppose it depends on how often you need to cut up 8 by 4 boards. I use my table saw with additional rests provided by my workmates to act as feed on and feed off supports. I have, on occasion, used my circular saw with a batten guide, as Ayjay recommends, just giving a small hand saw cut at the end to prevent the breakout. I can see that a cordless track saw is a must for someone working out of the workshop so I would say evaluate your need and whether it is a tool that you will have a use for. A table saw is a better acquisition if you have space as you can build a sled for crosscuts and it is so versatile. Even the cheap £100 ones do most jobs.
Excel Plunge Saw
Thanks for the tip about the handsaw cut.dewaltdisney wrote: ↑Tue Aug 25, 2020 9:06 am I suppose it depends on how often you need to cut up 8 by 4 boards. I use my table saw with additional rests provided by my workmates to act as feed on and feed off supports. I have, on occasion, used my circular saw with a batten guide, as Ayjay recommends, just giving a small hand saw cut at the end to prevent the breakout. I can see that a cordless track saw is a must for someone working out of the workshop so I would say evaluate your need and whether it is a tool that you will have a use for. A table saw is a better acquisition if you have space as you can build a sled for crosscuts and it is so versatile. Even the cheap £100 ones do most jobs.
I don't spend a huge amount of time cutting sheet materials but when I do it's often long lengths up to stock sheet sizes. I use my circular saw ( with guide ) for wider / heavier long lengths & table saw for skinnier / lighter long lengths. I'm quite happy with the table saw for cutting shorter pieces of sheet stuff. We're thinking about taking on some projects that might involve more cutting of ply etc so I'm starting to look at track saws.
