Flexi ratchet comby spanners
I've seen plenty 8-19mm sets on the likes of ebay but has anyone got a set that's proven reliable?
- Cannyfixit
- Has thanked: 102 times
- Been thanked: 183 times
I’m a service engineer and I bought a 10mm and 13 mm made by Teng I also have a Halfords 10mm all three are getting on for ten years old and worked flawlessly in my day to day work
- Has thanked: 94 times
- Been thanked: 857 times
It depends on what you are using them for, the flex heads can be irritating if you want to put pressure on them, halfords stuff is usually good quality, i do like Facom but it gets a bit pricey, the higher end draper is good too
It all depends on your budget
I've just picked up a 12pc set on ebay for £23. If they're rubbish they go back for refund. Being ratchet tools, I wouldn't loosen or tighten with them so no real strain on them. I'd use them for the likes of winding lower suspension ball joint nuts off/on and adjusting handbrake cables.
Thanks for the reply posts.
