Compressors are they worth it?
ahfix
Has thanked: 61 times
Been thanked: 184 times
Post by ahfix »
someone-else wrote: Wed Aug 12, 2020 3:03 pmI ended up buying a decent hose (The other one is cheap plastic, coiled up) and a proper tyre inflater.
But then it's not my money, if you want to waste £20 go ahead.
You are right about the pipe, it's no better than a bendy straw but the inflator is OK as is the blow gun. I was given a pipe so covered.
I needed to blow up a large paddling pool so accuracy was not a major concern :thumbleft:
Anyway, screwfix are pritty good so dont like it take it back.
ah
Argyll
Has thanked: 1168 times
Been thanked: 571 times
Post by Argyll »
Has thanked: 775 times
Been thanked: 3317 times
I think that the second guage is the setting for the working air pressure required and the first guage shows the tank pressure. The second valve needs to open to allow air through, Could you try a radiator key on it to get it open?
Has thanked: 42 times
Been thanked: 2488 times
I agree with dewaltdisney, the other thing is you said push..........and then pulled it, what happens if you push down (Gently) and turn it?
Rorschach
Has thanked: 100 times
Been thanked: 1022 times
Post by Rorschach »
On mine you pull it up to adjust the valve (not all the way off obviously) and then push it down when you are done to lock it in place. This is same on both of my compressors.
ayjay
Has thanked: 458 times
Been thanked: 1708 times
Post by ayjay »
I just turn mine, no pulling, pushing or locking.
Argyll
Post by Argyll »
I managed to get it going. The brass valve had been overtightened.
What the square one? if so what did you use to free it?
Argyll
Post by Argyll »
someone-else wrote: Tue Aug 25, 2020 4:01 pm What the square one? if so what did you use to free it?
A radiator key. It had been overtightened so the nylon knob slipped over it.
oh, frustrating or what.
I presume all is working now?
Argyll
Post by Argyll »
someone-else wrote: Thu Aug 27, 2020 1:47 pm oh, frustrating or what.
Yeah everything fine mate. I only wanted it to blow dust of something I had painted.
Argyll
Post by Argyll »
I just sold it for £200!
It was getting in my way and I was too lazy to take it down to my lockup. I advertised it for £200 not thinking I'd get that for it but a guy came out tonight and gave me the asking price.
Now I'm considering buying the Senco one Fin has :lol: All in all it'll only cost me £35 :lol:
Argyll
Post by Argyll »
Fin the one you posted is only 115volts.
Argyll
Post by Argyll »
Yes, don't buy it.
My first compressor was a stanley with 8L tank, I only wanted it to blow up (not literally) my car tyres, I figured, cheap, will do the job, stanley great. Er no. It was the tank size or lack of that is the problem, it struggled to do one tyre. A compressor uses the tank as reserve, so when you use it you use what is in the tank, and when you stop the compressor comes on again and refills it (Roughly speaking) but if the tank is too small the compressor runs all the time and can not keep up, so that is why I say, don't get that one, unless you have some balloons to inflate, get one with the biggest tank you can afford. Mine is a stanley, with 24L tank, well happy.
Argyll (Thu Sep 03, 2020 12:47 pm)
Return to “Tool Talk”
