Damaged plasterboard - Zinnser Gardz and skimming
- Has thanked: 2 times
I must apologise that I am a complete DIY novice but would greatly appreciate some advice:
We intend to re-paint the ceiling above a shower in a house that we've owned since new-build.
Shortly after we moved in, the paint started peeling.
We got a decorator to re-decorate it a year later and it peeled again. We've left it for years.
We are now going to do it ourselves and have scraped all the paint off.
Although a lot came off easily, the decorator had put something on that made getting the paint off some patches near-impossible and I needed to use a sander.
This sanding has got the paint off but also the skim coat in places, revelaing patches of plasterboard paper (some torn) and down to what I think is gypsum( solid and white) in places. The rest of the ceiling looks like skimmed plasterboard that has never been sealed.
We intended to use Zinnser Gardz to seal the whole ceiling (damaged areas of plasterboard and the remaining unsealed plasterboard too), then apply a skim coat on the damaged areas, and then also seal this with Gardz.
I just rang Zinnser to ask a related question.
They told me you can't skim over Zinnser Gardz.
I said this is what it says you can do on the tin.
They said the tin must be wrong but would check.
They rang me back and said you could skim but only small areas.
I asked what small was and they said I had to make that decison for myself.
They also said it was for drywall and not plasterboard.
I asked what the difference was and they said I would have to google it.
I am now completely confused.
Can we skim direct onto the exposed paper layer and exposed white plaster of the damaged plasterboard / drywall or do we need to apply something like Gardz first?
Do I have plasterboard or drywall? (There is a brown paper layer and something that looks like white plaster below that)
A simple explanation for an idiot would be much appreciated.
I
I'm assuming this is a joke based on the format of my original question? If so, will simplifying it to "can you skim over zinnser gardz because zinnser just told me I can't" get me the answer I'm desperate for?
- Has thanked: 61 times
- Been thanked: 184 times
OK, just re-read. You are not skimming the whole area.
What product do you intend to use to skim?
Btw, dont read my last reply as pva and then paint. That is a no no.
ah
ah
- These users thanked the author ahfix for the post:
- The Monkey (Tue Jul 07, 2020 10:06 pm)
- Has thanked: 139 times
- Been thanked: 113 times
I won't use Polycell skim...
Is the wall nice and smooth and you don't need skimming? Assuming you can patch what you damaged with polycell fillers. If so call Dulux, explain your problem and ask if you can use https://www.dulux.co.uk/en/products/dul ... er-plaster and paint on top?
If need skimming, as @ahfix said, pva and plaster then paint.
I would use Dulux Bathroom paint.
- These users thanked the author yartin for the post:
- The Monkey (Wed Jul 08, 2020 9:18 am)
Thanks for all the replies - what would you recommend instead of the finishing skim - that link was broken.
You dont say how large the damaged area is, for areas a couple of inches in area, something like https://www.screwfix.com/p/polycell-tra ... 1ltr/82124
Apply in thin layers and built up just above level and lightly sand back.
If the painted surface is flaky then a coat of this https://www.toolstation.com/zinsser-pee ... int/p44309
Read the instructions.
ah
ah
