I need help indentifying and obtaining hinge for upvc door hinge.
This is on an external opening door and the adjuster plate has shattered.
There is a number on the hinge but it cant tell the last number, it is A10331 or A10337
could you tell me what the hinge type is called and where to buy a replacement? Is there any other information I would to be able to buy the hinge?
thank you in advance
glassescase
Help required with upvc door hinge
- Has thanked: 39 times
- Been thanked: 3 times
- 4.JPG (65.1 KiB) Viewed 580 times
- 3.JPG (59.94 KiB) Viewed 580 times
- 2.JPG (59.73 KiB) Viewed 580 times
- 1.JPG (92.9 KiB) Viewed 580 times
- Has thanked: 283 times
- Been thanked: 397 times
That type of hinge is called a flag hinge and it looks like a avocet or era hinge but if you send the photos to https://www.google.com/url?sa=t&rct=j&q ... 3QVsNxujuV they should be able to tell you which ones are best suited to your door.
When I have had occasion to use these people they have been very helpful.
Mike
Mike
- sammy.se (Sat Jul 04, 2020 4:05 pm)
- Has thanked: 94 times
- Been thanked: 857 times
As above its 3D lift-off flag hinge
looking at the hinge pin plate and the cover it looks to be a Laird/Era nexus hinge these come in 2 sizes 100 or 85mm just compare the sizes
eg.
https://www.ebay.co.uk/itm/UPVC-Door-Fl ... d14389804b
https://www.ebay.co.uk/itm/UPVC-Door-Fl ... SwD6VdpciI
eg.
wow guys that is brilliant information, thank you so very much.
glassescase
glassescase
