Hello
I'm trying to install an air conditioner, but when I unpacked the indoor unit, I've discovered on the pipes those weird plugs (see image below), and when I tried to unscrew those plugs, a bit of pressurised gas leaked out...(I screwed the thing quickly back)
I thought that the gas was contained in the outdoor unit, and that you would put the gas circuit under pressure once everything was connected by unscrewing the nuts of the outdoor unit (thus releasing the gas into the circuit).
Can someone explain to me what are those weird plugs on the indoor unit, please...?
the air conditionner was bought at Leroy merlin, Aqua thermal, Aures series.
weird plugs on the indoor unit of my air conditioner
- Someone-Else
- Has thanked: 42 times
- Been thanked: 2487 times
Is this for your house in Cyprus?
- wil75
- Has thanked: 7 times
- Has thanked: 94 times
- Been thanked: 857 times
https://www.aircondirect.co.uk/files/pd ... 180810.pdf
thay are just test plugs when they purge and test the system in the factory, they also stop moisture and or contaminants getting it, once installed the system is vacuumed down and then charged/oiled
