Hi all,
I am really new to DIY and need some help, I have recently pulled down the wallpaper from master bedroom of the house I bought but I can still see some of the old paint and wallpaper at the edge of the crown molding. What is the most easiest way to finish it to prepare it for paint? I tried removing it with scrappers and water but it wasn't enough to remove it all. I have attached a picture on how it looks .
Would really appreciate some advice on this.
Thanks in advance
How to refinish crown molding edge?
- Has thanked: 775 times
- Been thanked: 3315 times
It is usual to run some decorators filler along the joint and this will hide the cracked bits and give you a paint line. To get it real level you could use a multitool to cut it slightly to make it level. I would not bother as the filler will make it look neat. The residue paper can be sanded off when dry. Here is an example of what you need https://www.screwfix.com/p/nemesis-migh ... 10ml/4774j and https://www.screwfix.com/p/p-c-cox-easiflow-gun/79714
