Opinions on this product please?
- Argyll
- Has thanked: 1168 times
- Been thanked: 571 times
I used to soak my posts in old engine oil but have recently used a bitumen paint. I saw this product and wondered if anyone has used them? It's not terribly expensive so maybe worth a punt.
https://www.postsaver.com/Postsaver-jou ... .html.html
- Someone-Else
- Has thanked: 42 times
- Been thanked: 2487 times
Heat shrink sleeving for posts, sounds novel.
- Has thanked: 100 times
- Been thanked: 1022 times
Apparently it works quite well. Why not do both and soak in oil and then use the postsaver. I use old engine oil on woodwork and it seems to do a very good job but it isn't a total cure for rot.
- Has thanked: 10 times
- Been thanked: 194 times
Is there not a danger of water getting in the top as the timber shrinks with age !
Concrete fence post are the only real solution long term
- Has thanked: 775 times
- Been thanked: 3317 times
I agree, concrete posts are best. I found that as good as the protection was underground the bloody post would always snap at ground level. The stump would be quite sound when I pulled it out. I hate wooden posts with a passion but not as much as Metpost fixing that are effing useless.
I think it’s funny putting timber treatment on fences , when the bit treated above ground never rots.
As DWD says it is the bit at ground level always damp and in nice oxygen rich air that rots regardless , do fence treatment a waste of time , money and effort
- Has thanked: 1299 times
- Been thanked: 1175 times
Do you know, I don't think I have either.dewaltdisney wrote: ↑Sat Jun 20, 2020 6:42 pm Yep, I have never painted a fence panel in my life.
And wooden fence posts always rot off. . .
On a number of occasions I have been asked why I haven’t treated my fence ! I have to explain and I just get odd looks like I have just got out of the funny farm ( maybe I have mmm )
- big-all
- Pro Carpenter
- Has thanked: 731 times
- Been thanked: 2309 times
wood rots at about 19% moisture more or less or constantly fluctuating it wont rot thats why fence posts' sheds at ground level and sheltered wood rot because it hovers around the 19% level for too long
- Argyll
If you read the blurb it states "Ground line rot and decay in the upper 150mm or 6” of the ground is the number one cause of Fence & Gate post failure". They claim this product eradicates this.dewaltdisney wrote: ↑Sat Jun 20, 2020 5:56 pm I agree, concrete posts are best. I found that as good as the protection was underground the bloody post would always snap at ground level. The stump would be quite sound when I pulled it out. I hate wooden posts with a passion but not as much as Metpost fixing that are effing useless.
Worth a try then. I accept that it is a major job to replace a run with concrete posts but they are usually fit once and forget.
