Adding Handle to Other Side of Window/Door
Hello everyone,
I was wondering if anyone with a bit of expertise in windows/doors could help me out with something I would like to have a go at?
Where I live we have a balcony with an access door to a common hall that leads to the elevator. This is the easiest way to leave the apartment if you are moving anything of any size etc.
Unfortunately the lock handle for the door is only from the common area to the balcony, and not on the other side (my side). So if I want to use it I have to go out of another exit from my apartment, all the way round another route to open the door from that side. Likewise when coming back I cannot lock it from behind me without going all the way round again, all I can do is close it over.
So I was wondering how would I go about adding a handle to my side of the door? The door is one of those window/doors and the handle is either down for locked, horizontal to open or up to open the window from the top with a small gap. I think they are called tilt and turn windows.
I haven't removed the handle yet to take a closer look at it but the two problems I can see are that the tilt and turn mechanism is quite complex, running all around the inside of the frame, so another handle on the other side will need to connect/activate all of the locking mechanisms, and that the handle on the side where it can be opened from will not align with just putting another handle directly opposite on the other side due to the shape of the door and how it sits in the frame. Hopefully you can see what I mean better from the attached pictures. The red handle in the diagram is where I would like to attache a new handle.
Anyway, I was just wondering if anyone had any experience doing this and knows what I need and how to go about it, any help is greatly appreciated!
Thanks!
Thanks!
- Door.jpg (7.91 KiB) Viewed 1179 times
- 20200618_112300.jpg (128.5 KiB) Viewed 1179 times
- 20200618_112251.jpg (123.18 KiB) Viewed 1179 times
- big-all
- Pro Carpenter
- Has thanked: 731 times
- Been thanked: 2306 times
if its a communal area it belong to the lease holder so you cannot touch it without permission
- Someone-Else
- Has thanked: 42 times
- Been thanked: 2487 times
- Someone-Else
Are you the sole lease holder?
- ayjay
- Has thanked: 458 times
- Been thanked: 1708 times
The handles have to be opposite each other in order that they can both operate the spindle which passes through the lock and moves the latches/bolts.
I've never seen a lock with an offset spindle hole, but if you call in to your nearest DG window supplier they might be able to help.
Check google maps for upvc window suppliers or makers
- big-all
- Pro Carpenter
you need to think off security with an operating handle on the outside you will need a lock and give everyone a key or some other way off securing the door when not in use on the inside so negating the ability to get in from the outside
The operating handle is already on the outside, I want to add one on the inside. Security isn't an issue as there is a locked iron, gated door immediately behind it.
Yeah, something with an offset spindle, like a Z shape or something was what I was hoping someone was going tell me was available. I tried Googling for something similar but no luck but I don't know any terminology etc. and figured it was a bit niche so thought there might be a locksmith or something on here who knew better.
