toilet Rod
- etaf
- Has thanked: 37 times
- Been thanked: 137 times
toilet Rod
I have searched this morning for toilet rod and mounts , but not found anything like this , found a rod, but not the mounts
We want to keep the toilet and the lid , but like to change the rod and mounts
Rod Dia is 9.6mm
The seat is made by Exco plastics and model is Exclusive
Any suggestions where in UK i can obtain a replacement
Rod Dia is 9.6mm
- Toilet Rod.jpeg (54.62 KiB) Viewed 2196 times
Simple DIYer
Wayne
Wayne
- Someone-Else
- Has thanked: 42 times
- Been thanked: 2488 times
toilet Rod
ebay, but look for toilet seat hinge
- etaf
toilet Rod
rusty , and as we about to refurbish the room, BUT wanted to keep the toilet, as replaceed others and they do not seem to work as well as this one , maybe the ECO water settings
so just the chrome bar, and the clamps
the hinges are part of the plastic
Simple DIYer
Wayne
Wayne
- Has thanked: 775 times
- Been thanked: 3317 times
toilet Rod
Why not a new seat? They are relatively cheap and come complete, and that looks like standard fittings on your existing WC.
- Has thanked: 139 times
- Been thanked: 113 times
toilet Rod
Will any of these fit? They look similar
https://www.ironmongeryworld.com/toilet ... brass.html (I think this should fit? Only use the rod and 2 round bases plus plastic nuts and washers)
https://www.plumbinbits.co.uk/celmac-hi ... el-fd211ss
https://www.ebay.co.uk/i/272240094643?chn=ps
https://www.plumbinbits.co.uk/celmac-hi ... el-fss13ss
toilet Rod
There is more here but much more expensive:
https://www.blackcountrymetalworks.co.u ... hinges.htm
