Testing Double Glazing in a Cold Room
- Has thanked: 25 times
- Been thanked: 14 times
I have a cold bedroom and I just can't identify why.
The latest straw I'm clutching is that the sealed double glazing units have some how failed. They are 15+ years old but there's no condensation or visible cracks hence straw clutching. They started life argon filled but that may have leaked away. Is there a method for testing DG units in situ?
It always takes longer than I thought
- Someone-Else
- Has thanked: 42 times
- Been thanked: 2486 times
What about the walls? do you get wind blowing more across the front than say the back? What about insulation above the room? (Loft?)
I just googled (as you do) and argon filled DG even at 80% filled will still work at 20 years.
This is going to be a long reply, sorry.
The room is a bedroom on the first floor and when the heating goes off, it cools quicker than any where else. Measurement shows 2C cooler than other rooms. This effect seems to have appeared over the past couple of years and wasn't noticeable before. The loft is insulated to 170mm for the entire building so no reason there for the bedroom to be cold.
And, yes, I have thought of hiring a IR camera but the cost has shot up these past few months.
- Two walls are internal and the adjoining rooms hold heat as expected.
- One wall is a party cavity wall with no cavity insulation. However, the other bedroom that shares the wall doesn't cool rapidly.
- The other wall is a cavity wall with cavity insulation and a large window. However, the adjoining bedroom that shares the external wall doesn't cool rapidly.
- The ceiling has a pendent light and the cable hole is sealed to prevent airflow.
- The cable ways to the electrical sockets are also sealed so there's no cold air blowing from sockets.
- The floor has carpet and is a suspended timber floor. The floor/wall joints are sealed.
- Where the joists enter the party cavity wall, I've sealed with PU foam to fill any gaps where timbers have shrunk over the years. No air ingress there.
- Where the floor joists go under the internal wall, I've packed with insulation so there's little to no air movement under the floorboards.
- Has thanked: 775 times
- Been thanked: 3311 times
You have not mentioned the thickness of the insulation in the loft above, and more importantly what room is below. It is possible that the caulk around the window needs to be replaced and this is allowing cold ingress as can perished gaskets on the window seals. I think I would experiment by getting some acrylic sheet cut to size and taping this over the inside of the whole internal window to see the effect. At least you could illiminate possible sources of suspected heat loss.
170mm rockwool
Below is a large lounge. That's not the source of the problem.
The UPVC windows were fitted my morons for Everest. Naturally they were fitted as quickly as possible with the least skill possible. Over the years as I have renovated, I've stripped back the edging and sealed the gaps between masonry frame. Also checked the unit seals and window seals. No air movement detected using candles while a storm raged outside.
Also tried removing the trickle vent.and taping over it.
Hence straw clutching.
- Someone-Else
If you are that concerned I see you have little option than to buy This Then sell it on after your one time use. Not as expensive as you thought?
Wrong tool for the job. It might work if there is a big temperature difference, but for anything subtle, you're wasting your time.
The problem is that it has a 32x32 IR sensor that maps to a 640 x 320 screen. Each IR pixel maps to about 200 screen pixels and it uses an algorithm to smooth the edges. There's also no thermal stabilization behind the IR sensor so the electrical noise means the temperature at the measurement cross varies . It should really read 16+/-1 it's so unstable.
Here's a pic of a window.
The walls are 3C higher than the glass and it's not easy to spot.
If I'm going to use an IR camera to spot the cold source, it would need to be the right one for the job.
