Any recommendations for worx batterys
handdrill18v 1.7ah
TIA
Replacement battery for worx
- big-all
- Pro Carpenter
- Has thanked: 731 times
- Been thanked: 2309 times
- Cannyfixit
- Has thanked: 102 times
- Been thanked: 183 times
You don’t say what model number you have but I think the 18v and 20v are the same in the Worx range ,don’t worry to much about the ah as the bigger the ah the longer you can use the tool
Have a look on here https://www.drill-battery.co.uk/cordles ... /6+WORX+18
Had my drill bout 10years
But battery's are not holding a charge
Maybe get a new drill instead
Which one tho
Like the worx tools, mostly for DIY work
Cheers again guys
Much appreciated
Which one tho
Cheers again guys
Much appreciated
- Someone-Else
- Has thanked: 42 times
- Been thanked: 2487 times
How long is a piece of string?
Yours is one of "Those" questions where you can ask ten different people and you will get 10 different answers, since you like worx, why not stick with them? (Or do what most people do, have a look round and buy the cheapest that is available at the time, its what I did.)
