Name of tool for this
No doubt an easy one, but just not something I've come across yet...
What do I need to remove this thermostatic cartridge? No lug nut or flats to get an adjustable on. It looks like it's be a basin wrench, but bigger....measures about 32/33mm across?
- Has thanked: 100 times
- Been thanked: 1022 times
- Has thanked: 94 times
- Been thanked: 858 times
A pin spanner will to the trick, If you get stuck you can tap the collar around with a hammer and a suitable tool (An old screwdriver will do)
- Has thanked: 1299 times
- Been thanked: 1175 times
- Has thanked: 775 times
- Been thanked: 3317 times
I thought that Dave, I bet the shaft it too big for the standard ring. Life is never that easy.
I thought the same as I typed it, but it's worth a look.
Somewhere I'm sure I've got an adjustable pair, But I haven't seen 'em for years, and I've got a feeling that the last time I saw them was before the last move!
I couldn't think of the correct name for the nut.............
It's a Slotted ring nut
the yanks call the tool a panel nut wrench
That's not what I called the last one I came across!
But sometimes nothing else would so the job.
The ones on camera lenses are the worst, they're usually tight as well.
- Cannyfixit
- Has thanked: 102 times
- Been thanked: 183 times
The pin wrench comes on different sizes we have three sizes at work and my angle grinder wrench won’t fit any of them
Yes Bob, it's for the steering head IIRC (or at least one is). Certainly on the M series like the M21 that's my avatar. I was only thinking before that I've still got the piece of pipe I cut and filed to make the tool.
BSA were fond of special tools!
- Has thanked: 283 times
- Been thanked: 397 times
