Ford fiesta 2007 1.3 petrol
Started with flat battery that wouldn't charge up (whilst connected to car) so bought a new one. Connected positive and when connected negative it started turning over (no key in ignition). So thinking it was a stuck solenoid on the starter motor I got a new one under warranty as it was only 6 months old. Fitted new starter, connected battery and started it up a few times and I thought job done. I then went outside a few hours later to here a quite whirring noise from the car. The starter was hot and so disconnected the battery.
What is the next check or issue, please help
Starter motor issue??
Thanks, new ignition switch fitted a few months ago so will buy a new relay. Thank you
