Power Shower Making Whining Noise - Help!
Hi there! I’m in the process of fixing problems around the house while stuck in quarantine and my Mira Select power shower makes a whining noise when you crank the heat and the power up. It’s been doing it for a couple of years now (the shower itself is 14 years old). I know it’s not the shower head or the hose as this is cleaned out regularly and has been replaced a good few times. What could be causing it and how can I fix it? Any help whatsoever would me MUCH appreciated. Thanks!
- Someone-Else
- Has thanked: 42 times
- Been thanked: 2488 times
If it's not the shower itself, then it must be the pump. Perhaps you can get a service kit for it?
